mrvavavoom
199
bandit country
when i come out to start my car in the morning and maybe during the day my car seems to lack power ie as if there is no turbo then when i pull over and start the engine again its fine it has been mapped and there is a 17705 code being thrown up can someone point me in the right direction
many thanks:)
mrvavavoom
199
bandit country
hunting feeling
hi guys also at full power ( naughty i know) the car seemed to hunt for want of a better phrase ie like i was backing off then applying the pedal constantly any ideas :)
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
17705/P1297/004759 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
Possible Symptoms
* Power Loss
Possible Causes
* Leaking hoses and/or pipes between components
* Check Boost Pressure Control Valve (N249)
Possible Solutions
* Check hoses and/or pipes between components
* Check / Replace Boost Pressure Control Valve (N249)
* Check / clean Throttle Valve, do Throttle Body Alignment
Special Notes
* Did anyone fitted an extra (wrong) dump valve?
Witalik
ROTTERDAM FEYENOORD
Dec 28, 2008
324
Netherlands
i have the very same problem ! thats odd !!
they have checked everything on my car ! except the DV so that is the next thing they goin to to now
mine also had a bad EGT sensor !
mrvavavoom
199
bandit country
Car surging
hi folks have a small problem, my cupra 1.8t feels when under power surges forwards then backs off and so on and so on can anyone shed some light it is remapped and boost pipes have been changed it is running a 007dv.
also when its cold ie first thing in the morning i am getting the no turbo feeling then if i switch it off then start it up again the power is back help its driving me nuts
changed the maf on monday also
many thanks
Cupra Ross
Breaks things............
May 15, 2005
1,379
Edinburgh, Scotland
Sounds like your N75 valve (boost pressure control) is on its way out, try a known good one and see if that cures it. A perfect excuse to upgrade to an N75J.
I had surging on my first Cupra with a GIAC remap. Never had the cold start problem though. My current car has a Jabba custom remap and is surge free.
id3als
many thanks
Very odd you posted this today, as im noticing the same on my Leon, mainly in 6th when overtaking. Car also feels a little resistant at low revs and lumpy idle when cold. I had one coil pack go on me last week which I swapped out, was wondering if any of the symptoms could be due to the other packs/plugs.
Think I will now also look at replacing the N75 with the J
Cheers guys
bozwellox
Jazz Maveric
Jan 8, 2007
136
Oxford
I am also getting the weird surging thing since having my car mapped last weekend. CC phase 1 and Forge 007P fitted. I'm suspecting spark plugs or perhaps early signs that the coil packs are on their way out?
mrvavavoom
199
bandit country
my 007p had a green spring in it so i changed this for a yellow one seems better but still surges maybe n75 valve will know tomorrow ordered an n75j as when i rang seat with the chassis no it came up as being an alternative although the one highlighted for my car was an A valve according to the part no ?
