Can i have a detailed description of where the thermostat is, im half way through a coolant change with a friend and was hoping to replace it, cant seem to find it anywhere.
I think it's down at the front left of the engine block... should be easy to spot - look for the casing that looks like the replacement thermo stat will fit into.
2nd guess would b above the gearbox, but I don't think it is there.
just follow the 'big' coolant pipes & you'll get there
On golfs and ibizas usually you have the coolant pipe going in at the front of the engine, if your car is flat or sloped down hill you can have an issue with the coolant only filling the radiator and pump side, and not getting to the engine.
I had this problem and the car would start and then stop. I solved it by jacking it up. which meant the coolant could flow in to the engine side, and the air would more or less to where the pipe to the expansion reservior goes.
Ha Ha. No such phone call yet. Although its the first time i have seen 96 degrees on my oil temp Many thanks arge for all your hard work while i supervised and of course to the knowledgable SCN crew for speedy responses
