Locked Keys in Boot
daniel_owen_uk
270
Chesterfield
Now I don't think this should be possible, but here's what's happening.
When I unlock the car and don't get in, the car locks after a set period. (good)
When I unlock the car and open the drivers door, the car won't lock itself at all. (good)
When I unlock the car and open the boot, the car locks itself after a certain period, when you shut the boot obviously all the doors and the boot need to be unlocked by the keys again. (Bad)
Now I recently had some accident damage fixed (on the boot) and am wondering if they have broke something.
lc_allan
Northern Monkey
Sep 15, 2006
3,389
Without testing, that sounds normal. I take it your drivers door is not open now?. You got a spare set of keys?.
Havok316
Boost Junky
Jun 6, 2006
1,220
Weston-super-Mare
hehehe reminds me what i done in my astra coupe. I opened the doors put the keys in the ignition and turned it to position 2 (one before starting the engine) closed the door and few moments later all the doors locked. Problem is the spare key wouldnt work couldnt open the door or the boot had to get the RAC to break into my car lol
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
No, not normal. I bet the boot light isn't working either.
It might not be down to the accident damage, the whole MkIV golf platform is reknown for the rear wash wipe leaking onto the boot lock.
What's happening is you're unlocking the car and opening the boot, but the cars not detecting you've opened the boot, assumes you've unlocked by mistake and relocks - just like the first scenario you mention.
Warranty job if you have any.
daniel_owen_uk
270
Chesterfield
Yup, that's exactly the scenario.
I will check the boot light.
But I do have a warranty, although think it will mean dealing with bloody autoworld chesterfield again :(
seatgirl
car locking itself? that would drive me crazy...id always be lockin in the keys!
lc_allan
Northern Monkey
Sep 15, 2006
3,389
I have the boot trim off on mine already, no leaks or had any in the past, boot light working etc.. if I open the boot it sometimes locks after a set period if the drivers door is shut and I have not started the ignition.
Not sure if it's faulty but then I've never had a reason to think otherwise like leave my keys in the boot. I unlock and put them in my pocket :p
scottR
150
Central Scotland
I've always been under the impression (given by the dealer) that this is correct - the car will stay unlocked only if you open a door, not the boot.
seatgirl
It usually don't lock it self, unless the doors are not opened.
So, unless you some how manage to get the keys in, without opening the doors, that won't be a problem.
that a relief...i can imagine myself havin 2 leave the window open all the time coz im desperate 4 leavin the keys stuck inside!
Oct 17, 2006
2,141
Mid Wales
Yep - the boot autolocks after 30 secs or so - i've heard this happen when I've been dropping someone off and press the button to unlock the boot for them - 30 secs later you can here the lock operating to re-lock
Jan 22, 2007
2,074
some may say lala land....
that is normal - i believe as does same for me &
even when your in car with ignition on, press the door unlock button the boot will unlock but lock after 15sec (guess work here as not timed) if you haven't opened the it
