Car been serviced,ECU reset TB alignment etc,how do the logs look
Code:
Wednesday 4 November 2009 19:40:27
06A 906 032 MJ 1.8L R4/5VT 0003
Group A: '003 Group B: '020
Engine Speed Intake Air Mass Throttle Drive Ignition Cylinder 1 Ignition Cylinder 2 Ignition Cylinder 3 Ignition Cylinder 4 Ignition
TIME Angle Sensor 1 Timing Angle TIME Angle Delay Angle Delay Angle Delay Angle Delay
Marker STAMP /min g/s % °ATDC STAMP °KW °KW °KW °KW
0.6 2760 84.36 100 11.3 0.01 0 0 0 0
1.51 3120 98 100 7.5 0.91 0 0 0 3
2.41 3440 109.5 100 8.3 1.81 0 0 0 5.3
3.32 3720 114.72 100 9 2.72 0 0 0 5.3
4.23 4040 123.94 100 10.5 3.62 3 0 3 4.5
5.13 4320 131.44 100 12 4.53 3 3 3 4.5
6.03 4560 140 100 13.5 5.43 3 3 3 4.5
6.94 4840 142.28 100 15 6.34 5.3 3 2.3 3.8
7.85 5040 144.47 100 15 7.24 5.3 2.3 2.3 3.8
8.75 5240 146.28 100 15.8 8.15 5.3 2.3 2.3 3
9.67 5400 151.53 100 15.8 9.05 4.5 1.5 4.5 3
10.57 5560 153.64 100 15.8 9.97 4.5 1.5 4.5 6
11.48 5720 156.64 100 18 10.87 3.8 1.5 3.8 6
12.37 5880 159.69 100 19.5 11.78 3.8 0.8 3.8 5.3
13.28 6000 161 100 21 12.68 3 0.8 3.8 5.3
14.19 6160 160.75 100 18.8 13.59 3 0 3 5.3
15.1 6280 162.28 100 21 14.49 3 0 6 4.5
16 6400 165.17 100 19.5 15.4 2.3 0 6 4.5
16.91 6520 165.56 100 23.3 16.3 2.3 6 5.3 4.5
17.81 6720 164.58 100 22.5 17.21 2.3 6 5.3 3.8
Code:
Group A: '115 Group B: '031
Engine Speed Engine Load Charge Pressure Charge Pressure Lambda Sensor Lambda Sensor Bin. Bits
TIME (specified Value) (actual Value) TIME Current Value Specified Value
Marker STAMP /min % mbar mbar STAMP
0.3 2800 164.7 2070 2110 0.01 0.992 1
0.91 3000 172.2 2070 2170 0.61 1.008 1
1.51 3240 158.6 2020 1970 1.21 0.93 0.953
2.11 3440 166.2 1970 2020 1.81 0.938 0.945
2.72 3640 160.2 1970 1970 2.42 0.93 0.945
3.33 3880 157.1 2000 1960 3.02 0.906 0.906
3.92 4080 159.4 2000 1990 3.62 0.891 0.899
4.54 4280 162.4 1970 2010 4.23 0.899 0.906
5.13 4480 157.9 1930 1940 4.83 0.883 0.891
5.75 4680 154.9 1910 1890 5.44 0.867 0.875
6.35 4880 153.4 1880 1890 6.05 0.852 0.867
6.95 5040 151.9 1860 1860 6.65 0.828 0.844
7.55 5200 148.1 1820 1830 7.24 0.821 0.836
8.16 5360 146.6 1800 1800 7.86 0.813 0.813
8.76 5480 146.6 1780 1780 8.46 0.797 0.805
9.37 5600 144.4 1770 1740 9.05 0.782 0.789
9.96 5720 145.1 1760 1740 9.66 0.75 0.782
10.57 5840 141.4 1740 1720 10.27 0.75 0.782
11.18 5920 139.8 1730 1730 10.87 0.75 0.766
11.78 6040 139.1 1730 1720 11.48 0.75 0.782
12.37 6120 141.4 1710 1740 12.07 0.75 0.758
12.99 6200 138.3 1710 1700 12.68 0.75 0.766
13.59 6280 135.3 1710 1700 13.28 0.75 0.758
14.19 6360 136.8 1710 1730 13.88 0.75 0.743
14.8 6440 134.6 1700 1680 14.49 0.75 0.766
15.4 6520 133.8 1690 1700 15.1 0.75 0.75
Code:
Wednesday 4 November 2009 19:47:57
Group A: '118 Group B: '032
Engine Speed Intake Air Charge Pressure Charge Pressure Lambda (add.) Lambda (mult.)
TIME Temperature Solenoid Valve (actual Value) TIME Self-Adaptation Self-Adaptation
Marker STAMP /min °C % mbar STAMP % %
0.3 2640 15 95.3 1760 0.01 0.2 -5.5
0.91 2840 16 85.5 2260 0.6 0.2 -5.5
1.51 3000 17 76.9 2000 1.21 0.2 -5.5
2.11 3200 18 82.7 2010 1.81 0.2 -5.5
2.72 3360 19 77.6 2050 2.41 0.2 -5.5
3.32 3520 21 77.3 1950 3.02 0.2 -5.5
3.92 3720 22 78.4 1930 3.62 0.2 -5.5
4.53 3880 24 78.8 1980 4.22 0.2 -5.5
5.13 4040 25 80 2050 4.83 0.2 -5.5
5.73 4200 27 78.8 1970 5.43 0.2 -5.5
6.34 4360 29 78.4 1980 6.03 0.2 -4.7
6.94 4520 30 77.6 1910 6.65 0.2 -4.7
7.55 4680 33 78 1900 7.25 0.2 -4.7
8.15 4840 34 78 1880 7.86 0.2 -4.7
8.75 4960 36 77.6 1880 8.45 0.2 -4.7
9.35 5120 36 77.6 1830 9.06 0.2 -4.7
9.96 5240 38 77.3 1800 9.66 0.2 -4.7
10.56 5400 39 77.6 1790 10.26 0.2 -4.7
11.16 5520 39 76.9 1800 10.87 0.2 -4.7
11.78 5640 41 78.8 1760 11.48 0.2 -4.7
12.38 5760 42 78 1760 12.08 0.2 -4.7
12.99 5880 43 77.6 1710 12.68 0.2 -4.7
13.58 6000 44 80.4 1740 13.29 0.2 -4.7
14.19 6080 45 78.8 1760 13.88 0.2 -4.7
14.78 6200 45 80 1720 14.49 0.2 -4.7
15.4 6280 45 77.6 1720 15.09 0.2 -4.7
16 6360 46 78.8 1690 15.7 0.2 -4.7
16.61 6480 47 80 1710 16.3 0.2 -4.7
17.21 6560 48 77.6 1700 16.91 0.2 -4.7
