Mr OCD
1,964
Manchester, UK
Thought would put these in here to see if anyone can see any problems?
All runs done in 3rd gear from 2500rpm to red line ... wanting to retain my licence I wasnt happy doing them in 4th gear.
Groups 003 and 020
Code:
	Group A:	'003				Group B:	'020
		Idle speed	Air mass in	Throt Angle	Ignit Angle		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization
	TIME	700-820 rpm	2.0-4.5 g/s	0.2-4.0%	0-12 BTDC	TIME
Marker	STAMP	 /min	 g/s	%	 °BTDC	STAMP	 CF	 CF	 CF	 CF
	0.59	2760	73.78	100	13.5	1.01	0	0	3	3
	1.5	3320	110.06	100	5.3	1.9	0	0	3	3
	2.3	3760	115.03	100	6.8	2.7	0	0	3	3
	3.12	4160	134.06	100	12	3.52	0	0	2.3	2.3
	3.92	4560	149.89	100	10.5	4.33	3	0	2.3	2.3
	4.83	5000	162.75	100	9.8	5.23	3	3	1.5	2.3
	5.72	5400	168.33	100	12	6.14	3	3	1.5	1.5
	6.64	5760	172.67	100	12	7.04	2.3	2.3	1.5	1.5
	7.45	6040	176.69	100	9.8	7.95	2.3	2.3	0.8	1.5
	8.35	6280	178.14	100	12	8.75	1.5	1.5	0.8	0.8
	9.15	6520	179.83	100	11.3	9.55	0	0	0	0
	10.06	4920	10.56	5.9	4.5	10.44	0	0	0	0
	10.86	3240	5.44	4.3	1.5	11.36	0	0	0	0
	11.76	3240	6.58	4.7	1.5	12.16	0	0	0	0
	12.57	3120	6.89	5.1	1.5	13.07	0	0	0	0
	13.47	3040	7.06	5.1	1.5	13.87	0	0	0	0
	14.27	3000	10.58	7.1	29.3	14.68	0	0	0	0
Groups 115 and 031
Code:
Group A:	'115				Group B:	'031
	Engine Speed	Engine Load	Spec. Boost	Actual Boost		Lambda Factor	Lambda Factor	Bin. Bits
TIME	700-6800 RPM	15-150%	990-1800 mbar	<=1800 mbar	TIME
STAMP	 /min	%	 mbar	 mbar	STAMP
0.4	2000	88	1510	1250	0.01	0.984	1
1.21	2320	121.8	1980	1550	0.8	0.961	1
2.01	2680	152.6	2080	1950	1.61	0.992	1
2.81	3080	164.7	2020	2040	2.41	0.953	0.953
3.61	3440	167.7	2010	2020	3.21	0.852	0.852
4.43	3840	161.7	2050	1990	4.03	0.789	0.797
5.25	4240	169.9	2060	2070	4.83	0.75	0.789
6.14	4680	168.4	2060	2040	5.73	0.75	0.782
6.94	5040	169.2	2060	2040	6.54	0.75	0.766
7.84	5440	163.2	2100	1970	7.44	0.75	0.688
8.76	5800	158.6	2030	1850	8.25	0.75	0.649
9.66	6120	149.6	1830	1810	9.16	0.75	0.649
10.48	6360	145.9	1640	1800	10.06	0.75	0.649
11.28	5640	10.5	1000	1140	10.88	0.899	0.891
12.08	4000	12.8	1000	1070	11.68	0.852	0.977
12.97	2680	12.8	1000	1040	12.57	1.991	1.047
13.98	2320	13.5	1000	1030	13.48	1.991	1.047
14.78	2120	12	1000	1030	14.38	1.991	1.047
15.6	1960	12.8	1000	1030	15.18	1.991	1.047
16.4	1920	13.5	1000	1020	15.98	1.991	1.047
17.29	1800	13.5	1000	1020	16.89	1.991	1.047
Groups 118 and 032
Code:
Group A:	'118				Group B:	'032
	Engine Speed	Air Temp In	Boost Dut Cyc	Actual Boost		Idle O2 Adapt	Run O2 Adapt
TIME	700-6800 RPM	<=110 C	0-100% 	<=1800 mbar	TIME	-10.1	-10.1
STAMP	 /min	°C	%	 mbar	STAMP	%	%
0.53	2280	34	95.3	1440	0.93	0.8	-8.6
1.33	2600	34	95.3	1830	1.73	0.8	-8.6
2.15	3000	34	77.6	2110	2.65	0.8	-8.6
3.05	3440	35	77.3	2010	3.56	0.8	-8.6
4.05	3880	36	80.8	1990	4.45	0.8	-8.6
4.85	4240	37	83.1	2110	5.27	0.8	-8.6
5.78	4600	39	83.5	2060	6.17	0.8	-8.6
6.58	4960	41	89.8	2030	6.97	0.8	-7.8
7.38	5280	44	95.3	1970	7.88	0.8	-7.8
8.29	5600	47	95.3	1920	8.69	0.8	-7.8
9.19	5880	50	95.3	1880	9.59	0.8	-7.8
9.99	6120	52	75.3	1840	10.39	0.8	-7.8
10.81	6320	54	54.9	1470	11.21	0.8	-8.6
11.6	6400	53	0	1250	12	0.8	-8.6
12.4	5600	50	0	1060	12.8	0.8	-8.6
13.2	3600	48	0	1050	13.72	0.8	-8.6
14.21	2640	46	0	1030	14.61	0.8	-8.6
15.01	2480	45	0	1030	15.41	0.8	-8.6
15.83	2360	45	0	1030	16.23	0.8	-8.6
16.72	2240	45	0	1030	17.12	0.8	-8.6
17.54	2120	45	0	1020	18.02	0.8	-8.6
18.44	1960	44	0	1020	18.84	0.8	-8.6
Groups 002 and 120
Code:
Group A:	'002				Group B:	'120				Group C:
	Idle speed	Engine load	Inj. period	Air mass in		Engine Speed	Spec Load	Curr Load	ASR Status
TIME	700-820 rpm	15-25%	2.0 - 4.0 ms	2.0-4.5 g/s	TIME	700-6800 RPM	0-399 Nm	0-260 Nm	active yes/no	TIME
STAMP	 /min	%	 ms	 g/s	STAMP	 /min	 Nm	 Nm		STAMP
0.01	1880	70.7	8.16	30.64	0.5	2040	399.8	178.4	ASR OFF
0.9	2160	106	11.22	47.08	1.29	2280	399.8	221.5	ASR OFF
1.7	2480	130.8	13.94	65.89	2.11	2640	399.8	266.6	ASR OFF
2.51	2840	158.6	17	89.75	3.01	3080	399.8	309.7	ASR OFF
3.41	3280	163.9	18.7	103.83	3.81	3480	399.8	301.8	ASR OFF
4.22	3640	163.2	19.72	114.36	4.72	3880	399.8	290.1	ASR OFF
5.12	4080	166.2	23.46	129.53	5.52	4240	399.8	288.1	ASR OFF
5.92	4400	166.2	23.46	139.36	6.33	4600	399.8	284.2	ASR OFF
6.73	4760	166.9	24.14	151.75	7.15	4920	399.8	270.5	ASR OFF
7.63	5120	164.7	25.84	159.67	8.03	5240	399.8	258.7	ASR OFF
8.45	5400	160.9	26.86	166	8.94	5600	399.8	243	ASR OFF
9.34	5720	158.6	27.2	172.75	9.85	5880	399.8	227.4	ASR OFF
10.37	6000	115.8	18.7	135.14	10.85	6080	399.8	203.8	ASR OFF
11.26	6120	119.5	19.04	138.86	11.66	5920	399.8	35.3	ASR OFF
12.06	5360	11.3	1.7	15.94	12.48	4760	399.8	0	ASR OFF
12.97	4080	12	1.36	9.47	13.47	2840	399.8	0	ASR OFF
13.87	2760	12.8	0	5.11	14.27	2680	399.8	0	ASR OFF
14.67	2600	12.8	0	6.5	15.09	2520	399.8	0	ASR OFF
15.49	2480	12.8	0	6.53	15.89	2440	399.8	0	ASR OFF
16.29	2400	13.5	0	6.33	16.69	2360	399.8	0	ASR OFF
17.2	2280	13.5	0	6.14	17.6	2240	399.8	0	ASR OFF
18	2200	13.5	0	5.86	18.4	2160	399.8	0	ASR OFF
18.8	2120	12.8	0	5.5	19.31	2080	399.8	0	ASR OFF
19.71	2080	13.5	0	5.42	20.11	2040	399.8	0	ASR OFF
20.51	2040	13.5	0	5.33	20.91	2000	399.8	0	ASR OFF
21.31	1880	13.5	0	5.25	21.71	2040	399.8	70.6	ASR OFF
22.12	2120	12.8	2.04	4.31	22.62	2000	399.8	0	ASR OFF
23.02	2040	12.8	0	4.56	23.42	2320	399.8	0	ASR OFF
23.84	2240	13.5	0	6.03	24.33	2240	399.8	43.1	ASR OFF
24.73	2640	12.8	2.04	1.72	25.13	3520	399.8	0	ASR OFF
25.53	3440	12	0	7.97	25.95	3400	399.8	0	ASR OFF
26.46	3400	23.3	3.4	16.56	26.94	3320	399.8	5.9	ASR OFF
27.36	3160	12.8	1.7	7.11	27.75	2800	399.8	0	ASR OFF
28.25	1920	39.8	4.76	14.75	28.65	1720	399.8	54.9	ASR OFF
29.05	1720	35.3	4.08	11.97	29.47	1720	399.8	51	ASR OFF
29.87	1760	32.3	3.74	11.06	30.27	1760	399.8	43.1	ASR OFF
30.67	1720	16.5	2.04	2	31.07	1720	399.8	3.9	ASR OFF
31.47	1720	12.8	1.7	4.08	31.87	1720	399.8	0	ASR OFF
32.28	1720	12	1.7	4.11	32.68	1680	399.8	0	ASR OFF
Comments? :D
Can anyone tell me if any issues with timing or vacuum leaks from these logs?
Log 115 shows that you actual boost tails off against specified after 5000 revs
Log 118 shows that the waste gate is almost fully closed at 95%
Is your car mapped? The only reason i ask is that the requested boost after 5000rpm is similar to mine, but mid range boost is well down. I was concerned to see that your wastegate is at 95% at 5000rpm but the actual boost appears to be quite a bit below from that point on.
Could be that your K03s is running out of puff, but mine is achieving similar requested boost levels with the wastgate only 85% closed. In short this could be a small boost leak. Try running 115 against 118 on the same log for a true comparison.
Timing adaption looks fine to me
The car is mapped ...
I will run 115 vs 118 next then...
Thanks for the input fella... Awesome GTi have looked at it and they cant find anything wrong with it and suggest using the rolling road @ £105+VAT per hour ...
