to start with i HAVE searched the forums so no snidey comments
Ibiza TDI 02 mk4
1.9 TDI PD130
as you may well guess by the title the little red light in the temp gauge bit, has started flashing, its usually when it gets up to 90C but the temp doesnt go over that it just sits there as per normal, ive checked the levels of course and water is flowing through the header tank
i have read people saying about its a common fault and its a case of cleaning the prongs in the header tank but mine doesnt have these, the one thing i have found is that on the rear of the heater tank is a recess for a connector and nothing is plugged in and i cant remeber ever seeing some thing in there, as well as there is no loose plugs hanging around. just looked at some engine bays and cant see any one else having a plug in there
so if some one could shed light on this, i have vag com and if any one knows where in vag com the fault may appear i would be very greatful as its really really fking me off now
cheers in advance
Lee
Ibiza TDI 02 mk4
1.9 TDI PD130
cheers in advance
Lee
