Low speed knocking noise
ad101
Hi I've got a 07 cupra and at low speeds there is this occasional knock which can be quite loud. I have tightened the sub- frame bolts, checked the anti-roll bar links and they seem solid and there is no play in the steering. Has anybody got any ideas
chopper-lew
311
Helensburgh, Scotland
I have this on my 09 plate K1. Exact same problem.
A dull knock, only noticable at low speeds, less than 15 mph. only needs slight road defect to set it off (cats eyes, drain covers, thick white lines etc).
I had mine back at SEAT a couple of months ago for it, and a couple of other warranty issues. They said they took various pannels off and found a couple of bits of loose trim which they padded and secured.
I was that pleased with the other major work the dealer had done, I failed to notice the knocking was still there the next day. They were convinced it sounded like loose trim, but im in agreement that it sounds like a loose suspension component at the rear.
TBH, they make such a meal out of doing any warranty work, its put me off going back and im just going to live with it untill about a month before the warranty runs out, then I'll take it back and get that and any other work carried out free of charge before the first MOT is due next summer.
If you find out exactly what it is, please post back, with photos if poss.
ad101
ok thanks guys i'll try a new pair of anti-roll bar drop links i dont think very expensive anyway.
Alzak
666
I have same problem at the moment and I can confirm this is not related to drop links as I fit new ones and noise is still there
I come across problem with movement on subframe on mk5 shape golf did leon share same floor ??
ad101
yes its the same subframe and ive tightened mine up and the noise is still there on mine
Alzak
666
lucky me I'm not on my own as my GF think I mad with this noise as no one can hear it is just me
Alzak
666
no way i do not spend this kind of money to have some knocking noise when I go over a bump.
I can live with dashboard noise as there is nothing what I can do, but I know there is something not right in front of the car
leon1p
XBL - dervturbo
Jun 30, 2006
382
Aberdeen
www.simplyrc.com
Mine is worse than it was.. but goes away when slightly applying brakes.. and when rolling in traffic if i apply the handbrake it goes away so I'm suspecting rattling rear inner brake pad.
Ordering up new brakes now so will see what happens.
Alzak
666
wow I just fit new pads all over so this is not brakes related as noise was there on old pads and so on new ....
Deleted member 65851
Same with mine!
Slight knocking noise from passenger side if going over slight bumps or ripples in the road.
Serviced at end of month so will get awesome to check it
Jun 7, 2006
2,983
Norfolk, Norwich
Does any one else need that car to have warmed up for 10 mins prior to the rattle starting. Makes me think it's a rubber that hard when cold and then more plyable when warmed. Exhaust mount?
ad101
I've not found anything yet but have noticied that with weight in the boot there's no noise whatsoever and then as soon as the weights out it's there again.
Andi_cupra
Any joy boys?? Iv had my cupra mk 2 for 8 months, had kw v1 fitted 3months ago I get the knocking everyday!! Doing my head in!! Can't seem to find it. Gonna try another garage this week!! Seriously considering going back jap!!!
