And use a lot of caution using them as they can slip and release the spring which can be very dangerous.All you need is some spring compressors from Halfords ro any other motor shop.
With a 40mm drop you'll be needing adjustable drop links aswell
yeah impact gun works to take off, should be retightned by hand though, torqued up.
undo top bolt, undo lower strut bolt, insert hub spreader, rubber mallet under strut...whack, comes straight out... i undid the arb mount bolt to lower the hub to get more room to remove.
Yeah I imagine it does, was weighing it up before as they're not exactly on stilts anyways are they, should look sweet.drops the cupra 35mm mate...... sits perfect tbh.
