Cool....thanks will have a sniff around and see where i can find it.
this look pretty sick man!!
job well done![]()
![Cool [B)] [B)]](/forums/styles/seatcupra/oldforumsmileys/shades.gif)
Not as far as I know..
The Mdi Kit and Ipod lead work out at around £140 - the going rate for MFD's from the right sources seems to be around 1,000 Euros - dealers list at around £1,500
Compass etc is enabled when you upgrade firmware to 1020/1024 which is available for download in quite a few places if you search
The speed cameras are as a result of a manually burnt & altered map DVD with the POI's burnt on and reprogrammed![]()
So can this all be done on an 07 plate system if you can alter the maps is it best to google it to find out how todo it and is it easy enough![]()
Looked for firmware upgrade before and never been able to find one![]()
Firmware upgrade is easy enough to find on torrents it's 1020/1024 that you're looking for.
Altering the maps isn't the easiest thing to do, it requires using a program that has been designed for altering BMW NAV Maps with several tweaks, and then linking this to a database that has the POI cordinates of all the speed cameras.
Then a new ISO DVD is burnt and then loaded on in the same way that you do when you upload new maps![]()
If you have the MFD2 then ignore all of the things I have previously said, as they only apply to the MFD3![]()
Does yours have a touchscreen and 30gb harddrive installed as standard? if not then it's not the MFD3![]()
MFD2 it is then I had mdf2 as well, could we not pay an little more to have the mdf3 and them take the mdf2. Sounds simple enought but answer now is probabaly no.
how much extra is it gonna cost me going down the ebay route?
Gutted it's going to cost that much I think it will go on the back burner for now but would like to grab one this year. Take it it's a straight replacement
