metal vibration from under LCR
mookster
51
I've got a similar noise at the moment but it is caused by bumps / poor road surface not engine revs. Is it still likely to be exhaust hangers or heat shield?
Booya
LCR 225
Nov 17, 2009
921
Glasgow, Scotland
Pretty east fix tbh! Just get some of that metal wire I posted a pic of on page 1 of this thread and wrap it round the exhaust till its tight then crimp it.
onapper
It could be the exhaust brackets, depends on like the sound it makes, if it's more of a tinny sound the it's the heat shield. if not then it could be the mounts like it has been mentioned.
yellow banana
Sorry to high jack your thread mookster[B)]. I have the same problem. But if I apply pressure to brake pedal. Sound dissappears. Check can find anything loose. Any ideas to try and point me in the direction of this so called vibration/rattle.
greganderson
131
Isle of man
mine did similar for a few weeks... then my back box fell off :'( lol luckily everything was still in perfect condition apart from one rubber bush :p
Feb 20, 2010
1,525
ipswich
Just looked under the car, one of the bolts for the lower heatshield has degraded/snapped off, and it is definately the culprit, my advice, when rattling occurs under the car, especially when cold, check the heatshield. I know my solution... de-cat!lol
Decat my thoughts exactly only £99 on ebay
cuprastoffs
299
Edinburgh-ish
Even easier just pull it off. I cant see a reason to put a heatshield on the bottom of the cat anayway.:confused:
PSX
271
Possible reason for the cat heatshield - in some cars, especially lowered and sports models (think TVR) - it's possible that parking over leaves or other potentially flammable things could set them alight unless the heat radiating from it is diffused somehow...
Alex
