Minimum brake Disc Width LCR
Sulli
3rd Cupra
Ooh bugger - they looked pretty OK to me, just a bit of a lip, but best try and get hold of a micrometer. Or is there an easier way to measure them without one?
Cheers, by the way.
Edit: Just a thought, that's a small tolerance on thickness by the way. the new discs are 28mm, and new pads around 15mm per side, so that's total width between pistons of 58mm approx. Pads wear down to 2mm either side, which reduces space between pistons to 32mm, 30mm if discs are also worn a mm either side. New pads go in and the space increases greatly.
I understand that the discs need to be a certain width to be effective - is that really 26mm???
Cupramax
Uber pimp meister
Aug 1, 2001
3,977
If you can see a lip they've probably had it, thats how mine were when I did them.
vern
I Miss Her Below!
Jun 17, 2003
2,020
N.Yorks.
seatcupra.net
Cheers, by the way.
These discs always end up with a lip mate, dont worry micrometer is best for being accurate, and a dial gauge to check for warpage, easier to just replace em, they are a very consumble item om LCR :(
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
Sulli said:
So explain :cartman:
thinner disks get hotter faster...., pads when worn in combination get extended further on the calipers pistons....
and they want you to buy new ones.. :)
Sulli
3rd Cupra
The discs are around 26.46mm - so within tolerance.
In an ideal world i'd just renew them, however at £100 a side, unless quattroman sorts some cheaper ones from LEDA, i'm tempted to run it a few more months - they won't wear that quickly.
Any comments?
CupraR-Rog
Just Cruising...
Jul 19, 2003
2,291
West Somerset
The thinner the disk gets, the noisier it gets!!
I ran my original disks way below 26mm - Bill, do you remember them?
When I sold my car, the replacements were even worse and extremely noisy!!
LCR's eat brakes, and oddly the rear pads have a longer life than the disk also!! At 26.46mm, you might as well put the money to one side ready to change them, but personally I wouldn't change them until you next do your pads...
Also, in terms of cost, why not ask Bill what he does them for these days?
Sulli
3rd Cupra
Cheers Rog.
I need pads really - there's still some friction material left, but not much, so intend to do them pretty soon. So I intended to do all at once, but the cost of discs puts me off really, till i desperately need them (as long as it's safe to do so).
I think i'll only do discs if quattroman can get the Galfer ones fairly soon at a decent cost, then i'll do discs and pads at same time.
quattroman
193
Devon
My Leda contacts are at the Autosport show doing their suspension stand, as they have a pretty good reputation in that field for doing bespoke suspension set ups for track and rally and are well known thoughout the racing fraturnity.
They told me (after inviting me to the show, alas couldnt get the time off work)that the M.D. of Galfer Spain was going to be at the show today and that the standard LCR discs would be a top subject on their list to talk to him about.They are aware that there are alot of people on here who would buy these providing the price is good and if there is enough interest,then the discount would be large.
So any body who wants them, keep an eye out as they should be available soon, as they are now listed on the Spanish Galfer sites catalogue.
