motty_90
91
Ashby De La Zouch
my car starts up fine and runs fine on choke, once choke is off the car runs on 3 cylinders. its had 4 new plugs and coil packs still does it. any ideas?
any eml's...going to be the same answer as most people give but.....vag-com and check coilpacks etc etc the most common thing on missfire. Are they genuine ones aswell..??
I had it plugged in because the engine management light came on because i disconnected the n249. pluged it back in and cleared the fault it then started misfiring. I dont think there genuine coil packs there off ebay and yeah its got the right plugs in.
you could always try it mate, if i was you i'd go out and just push the wires that go into the connectors for the coilpacks in a little bit just to make sure they are making a good connection (that's what i did when i had the same problem as you and it cured it)
