Mk 2 Cupra Sport Standard Wheel Nuts!
mickyggggg
38
Hi guys I recently went to fit some mudflaps to my car, however when i got the jack out etc an tested the wheel nut spanner it is too small to take them off!!! :cry:
Does anyone know anyone or have one spare or where I could buy one from to take off my wheels as obviously I need one for any emergencies also!!
thanks guys!
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Havent you got a decent socket setwith a extender bar? ive always used that then got them torqued up after, Failing that you could always go and buy a wheel brace from any autoparts shop?
David.
mickyggggg
38
No I wish I did!! I just assumed it would fit its my own fault but im glad to find out now than in a emergency when I would really need to use it!
I was contemplating a wheel brace but since the jack is knakered also I figured I would try and get a hold of a SEAT Jack set!?
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Could do, Ideal in emergencys but bloody hard work, Ever tryed jacking up a high top tranist with one at 8.30am :censored:
David.
jcs356
Cordy owner
Jul 12, 2004
1,161
Englandland
You can get a cheap extending wheelbrace with a double ended 17 / 19mm socket from Wilkinson for about £4. As Peter says, it will be 17mm if it has standard bolts, and likely to be 19mm if someone has converted it to studs.
