Mk2 Leon Part numbers/Pictures
KebabWarrior81
1,841
Sandbach,Cheshire
Bluetooth Module 5P0862335B
Part number and images kindley supplied by Daniel-M
richicupra
1,826
9
Intercooler charge pipe O-ring/seal for plastic-ended IC, as these can often cause a boost leak or leak oil onto the undertray. Part numbers are for the latest green O-rings.
Seal A (one located at each end of the IC): 3C0145117H, corresponding metal retaining clip is 1J0145769H
Seal B (slightly smaller and located at the turbo end of the boost pipe on the IC inlet): 3C0145117F, corresponding metal retaining clip is 1J0145769B
To replace the full set, you need two of seal A and one seal B. I would recommend replacing the metal clips too as they can bend out of shape easily and are less than a pound each.
Daniel M
Blackbelts & Chickenheads
Apr 18, 2013
2,874
7
Middlesbrough
Gearbox mount.
Is for an FR PD170, however I imagine they'll be similar across the range.
Part number - 1K0199555T
Its the one at the bottom ;)
Price is £54.41
VAT is £10.88
Total price - £65.29
I bought mine from TPS
AlexK1
545
Poole
TFSI Fuel vapour purge valve (p0441 fault code)
06E 906 517 A - I paid £21.17 plus vat
TFSI fuel injector repair kit (when removing inlet manifold)
06D 998 907 A - I paid £38.16 plus vat for 4 of these
