Ok. it *should* be 6K4 839 205 B. I say it should cos etka is **** as always,,, there are about 20 different handles, lhd, rhd, primed, black and all the possible combinations, these are identified with the 6K4 839 205 code with a different last letter for each one,,, when it comes to the handle without the keyhole, it says it's the same code for left and right [which is obviously impossible] and there's no primer option [maybe they already come only primed since these handles are only for models with colour coded handles???],,,
anyway, now you got the part #, maybe your dealer can help you a bit more,,, hope to have helped,,,
ta very muchly!
im giving them a call on my break in an hour so will let you know
Forbez - I don't know if this is of any help or if it has been covered already, but i got four new coilpacks this morning and i believe the part number to be:- 06B 905 115 R
Don't know if this has been mentioned before or even if it of use to anyone, BUT i have found a russian site with pictures and part numbers on.
It is in Russian but if you click on a name most of the time it displays a picture, then when you click again all the part descriptions are in english.
http://www.elcats.ru/seat/#3
can anyone get part numbers for the rear parcel shelf support o/s, and can anyone tell me if i ordered the front bumber would i have to buy the grills etc again, or does it come complete, lastly i wanted to order the black (smooth rubbing strips) but baastard said the fronts come with holes in and the backs no recess for the numberplate can anyone help cheers.
I went for the cupra front bumper [mine is a sport]: the part # for the front bumper is the bumper alone, then you might need the grills [center and sides plus the lower one] the 2 screw caps, the foglights and the foglights mountings, the black plastic part inside the wheel recess cos it's different for the cupra.
As for the bump strips I had the bodyshop ordering the parts numbers that were written on this thread and, to my astonishment, the front one had the headlights washer hole [didn't think some ibiza had it] and more than that, the rear had no space for the number plate,,, this is very strange cos I thought the rear bumpers were all the same for all ibizas but I saw that with my eyes,,, maybe the bodyshop messed up the orders?? :confused:
anyway, ended up with painting the original bump strips and they came out very good so you can go with those,,,
need to order new top mounts and rubbers asap as im fitting a set of FK's at the wknd, iv searched and kind find any clear instructions for part numbers. So:
Suspension Mounts and Bearings
Front
6N0412331E
(6N0412331D)
whats the difference between the two and are bearings included????
Rear
191 512 333 (Lower) - Need 2
191 512 335 (Upper) - Need 2
need to know asap as i got to order to get them before the weekend.
Had a quick look through dont know if this has been added before,
Passenger side apperture door seal : S6K3867365G 15.41 + VAT
David.
Powerflex bushes.
- PFF85-204 Front Lower Wishbone Rear Bush
- PFF85-201 Front Lower Wishbone Front Bush
- PFF85-202 Front Eye Bolt Mounting Bush
- PFF85-250 Front Subframe Bushes
- PFF85-232 Steering Rack Bush
a few floors in the list of parts
1M0 071 400 A is for the seat badge not the whole centre cap £30.60 four 4 sticky badges is cheep not
Outside Temp Sensor - Sensor in the wing mirror: 6K0 919 379
you will have to chop the big multi plug off that comes in the box and crimp the new sensor on but it does work in the end £18.71 from seat
manifold gasket exhaust for AQX engine code 058-253-039-L £4.09 will let you know tommorrow if it fits
Interior door parts(inc colour code) as they tend to wear out quickly:
Handle recess upper part drivers side for Ibiza Cupra -
6K0867172B 54H £12.34 inc vat
Handle recess upper part passenger side for Ibiza Cupra-
6K0867171A 54H £12.34 inc vat
Trim for handle recess drivers side for Ibiza Cupra-
6K0867198H 54H £3.31 inc vat
Trim for handle recess passengers side for Ibiza Cupra-
6K0867197F 54H £3.31 inc vat
good job pete!
I want to point out tho that there's quite a few versions of those handles depending on the colour you got [basically various shades of gray and black if I got it right]. The ones that tend to wear out easily have been replaced,,, will see how long they'll last on mine,,,
