MK3 Cupra Track/Race car - New Build
R4cup
Beef NO Burger
Jul 28, 2006
1,757
In the garage
Superb work mate. i look forward to seeing future progress. I had the exact same issue with rusty holes when i removed my carpet, very common, ibiza are getting old now but its nothing a welder cant sort.
Subscribed ;-)
Aaron87
272
Thanks dude!!
Some pics of the last two weekends..
Firstly, welding in the cage feet
Then the rust holes in the floor needed welding up..
Then I moved onto the engine bay and tidied that up a little
Can anyone tell me what's been done here? One Vac hose goes to nothing...
This weekend I removed the cage and painted it
Next job was to refit the cage
Next was my harness
Seat in
Few pics from outside with the cage fitted
Took it for a proper drive today as the weather was really good! It was ALOT of fun!!
Now I need to fit the solid engine mounts, top mount the shifter and decide on what turbo to fit!!
Happy with the progress so far
Aaron87
272
Away with work again this week, although hoping to get back for tomorrow so I can carry on fitting parts I have laying around!
Is anyone interested in a drivers side OMP subframe? I have an extra one....
Gloves
Nice work - will be following.
This is the kind of thing I would like to do as well. Think the ibiza cupra would make a great track toy
Aaron87
272
Thanks dude! It just takes time and practice. The key is getting things set up correctly.
Removed some more bits today.. Firstly I lost almost 4kg of weight from removing the rear arches and all the mud and crap that dropped out!! Maybe this has been a rally car haha!!
Next I removed the SAI pump and old engine mounts which where replaced by my solid ones!
Car seems pretty stiff!
Not driven it yet as got a wedding reception to go to now...
More tomorrow!
Aaron87
272
So... Progress has slowed up a little of late.
Ordered some more parts - Powerflex Black series top mounts for the rear & Rear ARB brackets from Bill.
Plenty more to do still but been enjoying driving it really! Will be booking its first track day in the next couple of weeks but got some work trips coming up.. One to the Nurburgring so tempted to take the car out there with me!!
Does anyone know where i can get a solid gearbox mount from? Also what top mounts are people using!? Ideally want solid ones....???
Aaron87
272
Awesome thanks dude! Yeah will 100% do some track days with you as your really local to me!.. Clio going well?
Aaron87
272
As the weather was so nice over the bank holiday weekend I thought it would rude not to do some bits on the car!!
First job was to top mount the shifter
I found what I expected too as the car has a 3" exhaust fitted.. Plenty of melted rubber!
Stripped the melted bits off as no longer needed
Cleaned and painted the shifter
Then fitted it and drilled the holes in the bulk head for the cables
Job done!
Then my Powerflex black race rear top mounts arrived so I removed the rear damper which looked really really bad although they're working really well still so stripped them down, cleaned and gave them a refurb
Before
After
I then run into a slight problem as the Powerflex Black bushes seem to required a different size sleeve as the fit was like a p***k in a bucket.. So I popped down to my local engineering guys who are making up two new sleeves for me.. These should be ready later today
After that I was bored, so started to remove the turbo to replace it with one of my others I have in the garage.. Although I spotted a bell housing bolt had fallen out!!
I can only guess it's from the extra vibration caused by the solid engine mounts. Time to loctite them all!
Anyway.. More updates to follow.
Still looking for some front solid top mounts.
Oh and I bit the bullet and ordered a new car yesterday too..
Seat Leon TDi SE in this colour
Aaron87
272
Thanks dude!.. What cutting needs doing?
Got the rears sorted today now the sleeves have been machined.
Old sleeves vs new
Dampers refitted
Then I finished removing the old turbo... What a PAIN! Usually jobs like this are pretty easy for me but this was a pain. Snapped bolts, rusted and seriously tight bolts!! Hardest part was getting the downpipe off..
I went to start fitting the new turbo but then spotted this..
:-( will get that drilled that out tomorrow.. What a bitch!
So as I couldn't do anything I heat wrapped the downpipe.
Not much more to do now.. Although I keep thinking about other bits I could do while its in bits again.
Also brought some rear ARB brackets off Bill for my 28mm H&R ARB although they don't seem to fit.. Do I still need the little rose joint drop links to fit these also!?
Aaron87
272
nice one Dean.. As I thought!
Will pick up some rose joints when I'm back in the UK.
I'm pretty sure it's 3" ... although you've got me questioning now. I'll check it when I'm back!
