MK3 Cupra Track/Race car - New Build
Aaron87
272
Yeah, diff is something I NEED to buy...
Any suggestions?
Oh cool, closer than I thought then! I'm quite often in Rugby anyway.. About to start training @ a new boxing gym there too.
Aaron87
272
Nice one, I'll check out AKS now.
BakeHouse in Rugby.. I've been boxing & kickboxing for 17 years @ British level, spent 4 years as British Champion. Since moving up North I've been looking for somewhere to train out of, this looks like the best option locally! ..
Took the car on a run this morning and was rather shocked that it hit 155mph!.. From some research it looks like the FD Ratio is good for 170-173mph..
When I'm on another work test site I'll be giving that a go!
Aaron87
272
Cracked on with a few bits tonight..
After the high speed run today I thought it would be a good time to upgrade a load of stuff with parts I have sitting in the garage
Got the car in the air and ready to go!
First job was the solid gearbox mount, giving me 3 solid mounts now!
New vs old
Fitted
Next I was going to fit the 312 brakes, although realised I need to drill the discs to 4x100 and also left the carriers in the Leon & the wife was out so that idea stopped there!
Decided I'll pull the wishbones off for a refurb as they didn't feel great and steering inputs where not so positive, think I found out why!
Next job was to removed the old ARB and replace with the Nuspeed one & fit my lower brace
New vs old
Both fitted
Next was the 4 bar FPR that's been sitting on my parts shelf for a couple months
Also started to cut out the holes for my aero catches & made a card template to make cutting a little easier!
I'll have these up for sale very soon if anyone wants them..
Been told they're G60 callipers.
Brembo Max discs & Yellow stuff pads. Loads of life left in both. PM me if interested
That was it for this evening.. Not bad for a few hours.
Car left in the air over night ready for the next phase
Aaron87
272
Thanks dude!
Trying to progress things as quickly as possible.. Keep getting to a point where I think I'll stop then I order more parts :)
AshBoy
34
how is this build coming along should be finished by now? and did u decide to go ko4 in the end. p.s you got some knowledge to this kind of build i would kill to have this knowledge so i could do my own build. hat off to you dude!!
Aaron87
272
Hey dude..
should be finished??!! A car build is never finished.. Just 'ongoing' haha..
I've had it on the road quite a bit.. Covered around 1000 miles in it now. Keeps coming off the road for more upgrades tho!
Didn't go K04, went K03s as I felt a K04 would be over kill on a track with a car that isn't known for it's handling abilities! I don't want to under steer off at every corner or on boost mid corner haha!
Thanks for the comment though! It's really not too hard to build something like this.. I think you'd be surprised how easy it is if you have a few basic skills / tools.
acid_ash
70
Bristol
nice progress mate :D those bushes are fubared! as said a k03s in this light car is mental power to weight all day :D
Aaron87
272
It wouldn't be a normal weekend without an update for me lately..
Firstly, spent a load more money on ordering parts this weekend.. About £500 in total.
Losing count of how much I've spent so far!
This weeks updates are for handling mods mainly..
Firstly, 312mm brake upgrade
New over laid.. Old discs and callipers are still fitted under there!
New vs old
I had 4mm milled off the carriers, wasn't quite enough!
So I had to get the grinder out!
Fitted properly after this was done.
Then after finally getting the old brake lines undone with a little heat assistance it looked like this..
Then cut the holes in my bonnet for the aero catches.. Didn't take any pics while fitting so here they are all fitted
Picked up some asap coilovers pretty cheap!
Finally,
Burn baby burn!!
Aaron87
272
Thanks Baz!
Got a few more bits done this weekend.
Firstly, wishbones where stitch welded to add a little strength
Then primed
I thought I had some black metal paint in the garage... Could only find red.
Oh well..
Black series poly bushes fitted
Then went to put it all back together and noticed to fit my ball joint extenders and rose joint steering arms my hubs would need some work... I could of simply drilled them out to 12mm, although as they're originally tapered the only contact on the bolt would be towards the bottom giving it very little contact so off to the machine shop and we drew up and idea for some inverted top hats to be made and fitted.. Will get them back next week, so while waiting on that i remembered my rear boot latch rattled a lot
I had another set of aero latches laying around so fitted them..
Then took some weight out of the tailgate
Aaron87
272
A little while since I updated this...
So. Had my hub mods completed. Ball joint extenders, track rod end machined and a top hat bush machined up and flipped to reduce bump steer.
While at it I fitted new inner steering arms to freshen everything up then fitted my rose joint ends.
The difference in handling feel and steering inputs is amazing! The car feels much more balanced and stable at speed and understeer has been reduced a lot too.
Also took the chance to fit my new AP coilovers
Then threw the 312 brakes on again
Had some of my company stickers laying around so chucked some on the car for a little free advertisement!
Then brought an ITG induction kit and fitted a 4" cold air intake - currently the ducting is sitting behind the bumper, waiting on an alloy intake
As the picture above shows I relocated the battery to allow room for the kit to fit, while doing this I took advantage by purchasing a lightweight race battery
Next job was to fit the black series front subframe bushes..
Step one.. BURN!
//images.tapatalk-cdn.com/15/06/26/3195279fe3e726271e1b6d2863e36464.jpg[/IMG
Then paint and ready to fit!
[IMG]//images.tapatalk-cdn.com/15/06/26/a90bd501cb5fc29f97d97783057289a0.jpg
Car then sat back on all 4 wheels for a couple of weeks due to a new addition to my family!
Eventually found a little time to do some of the little jobs..
FIA/MSA stickers turned up
Then fitted a sun visor as was getting fed up of being blinded!
That's about it for now... Car drives so well.. Vibrates a hell of a lot due to the amount of solid mounts and bushes but it's not a road car so I don't care!
More updates to come though, had this package turn up from Bill @ Badger 5.... Any guesses what it could be?
