mk3 ibiza cupra 'estate' 20vt
Martin M
www.midnightmotors.net
Nov 12, 2006
1,322
Kent
Hardest part on mine was trying to feed the loom into the tailgate!
Looking forward to seeing it all finished.
Vagtechniek
Nice project with a Vario! This is my car, no 20VT though ;)
roly
midnightmotors.net
Jan 2, 2002
1,883
Midnight Motors Workshop
wheres ben when you need him lol
Welding wire and brake pipe are your best mate for the tailgate loom, also taking the connectors off so only the wiring and pins are left makes threading it through easier.
Rest of the looms plug and play, although your mating the 2 together in places so could be fun
h17och
the hunt is over. 460bhp
Sep 1, 2005
3,504
Dunstabubble
i manged to crank her over today!!!!
wouldnt start due to the aftermarket alarm it had. i ripped it out but i think im regreting it now :(
ut oh !!
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
It's not too bad - I stripped an aftermarket out of my 16v loom - you're far better off without it.
Check the main wires to & from the barrel lock to see what's been cut into
h17och
Sep 1, 2005
3,504
Dunstabubble
looks like its been cut into by the fuse board. the main chack of loom that is there as been re-taped.
gonna start there
h17och
Sep 1, 2005
3,504
Dunstabubble
dash board on order. £115 delivered!!
still dont run.
no power to fuel pump. and no power to serial port.
any ideas?
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
it'll be boring wire tracing to find the one that was cut into, and going into the alarm.
shame I'm away a lot over the next few weeks, otherwise I'd come and do it for you
h17och
Sep 1, 2005
3,504
Dunstabubble
found a fault code in airbag section....
00595 crash data present.
looks like i need a new airbag module!!??
how easy are they to break as i had the car running before i stripped it so i guess it didnt happen in the accident!? not sure if i dropped it or not:shrug:
also are they plug and play as i may try my ibiza one!?
thanks for the offer mork....you must be missing the vario lol:D
HoocH
h17och
Sep 1, 2005
3,504
Dunstabubble
thinking about it i dont htink its the problem..
i have continuity from fuel pump relay to the ecu (signal wire)
the main live is live
earth is good.
the 4th wire on the relay, according to the wiring diagram goes to crash sensor t9a/8
anyone know what that is?
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
I think that when you have a crash and the airbags fire - it cuts the fuel pump connection.
I guess you either need to hold it high or low....
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
Connect it to +12V or Earth (high/low)
depends what the other side of the relay connects to (have you got a pic of the FP relay with the diagram printed on it?)
