the rears are the same as on the 8v, 16v and the mk3 cupra`s, but yes you are right you will need the stubs of the mk3 as the bearing set up is different
the only reason i went for the mk3 set up was that it was there when i needed it. the only thing different is the bearing set up like i say so whether its any better than the mk2`s, im not sure!
