Im slighlty confused about which bushes i actuly need, the most coomon replacement is the front rear bush, right? and thats thes same on both sides? so that means the front front bush is fine? and the part number for the front rear bush is 6LL407183, right?, also im going to attempt to replace them my self, so if by replacing the front front is quite a simple job is it worth me doing it while i do ther other one/ if so whats the part number for the front front bush?
Why do you need to change the bushes?
What will it improve if i change them to cupra ones on my 1.2?
There are lots of mentions in here about coilovers and ajustability, it would be good to have some feedback on non ajustable kits. What is a good route to go for a straight forward lower / uprating kit with no ajustability? Ride height to lower no more than 25 - 35mm..
I'm thinking Koni FSD's & Eibach spring combination, Eibach pro damper / spring kit or possibly the Sachs Sports shocks Eibach spring combination. However there is some poor feedback over on Briskoda regarding the Sachs Sport Shocks.... Anyone got just a non-ajustable kit fitted? Any comments if the ride quality is better than standard and how they've lasted?
