Modifications... Leon Cupra TDI
d_cook88
zιℓ∂נιαη - ρℓαу ωιтн ƒιяє
Aug 28, 2007
128
Preston
Ok whats ARB's? bushes where? and whats a dogbone mount? i have the pannel filter, short shifter and strut brace im currently lookig in to :) So not to bad of a list :) As for the brakes, i will look in to them when they wear down as thye cost a fortune to disguard part worn!
Edit: Also im after uprated boost pipes, anyone know where i could get a full set and how much for? Cheers!
Dave
S3 AKR
livin' the dream!!!
Jun 30, 2004
1,453
Colchester, Essex
ARB - Anti roll bars - part of the suspension that prevents/limits body roll. The more uprated the less roll and the more even the contact with the road across all 4 wheels hence more grip and better handling.
Bushes - in essence bits of rubber in the links between suspension components that have a certain amount of give in them to allow the links to move around and help absorb small bumps to stop them vibrating through the car. Uprated they limit this movement and keep the suspension geometry nearer to the perfect setting and improve handling, but can allow small bumps and road imperfections felt more in the car.
Dogbone - limits engine movement and weight transfer under the bonnet whilst isolating some of the vibration to the occupants of the car. Uprated it can allow more vibration to be felt but limits the engine movement more and helps with handling.
d_cook88
Aug 28, 2007
128
Preston
Wow thanks very much thats interesting, so would you agree these are a good idea if i were to want for a bigger turbo? Also where would i get such parts? I did a google search on the ARB and it got me nowhere, im also after some stronger boostpipes? Have you got any of that stuff on yours?
jonjay
50 Years of 911
Jun 27, 2005
5,843
Essex
Have a look at the readers rides section, there is quite a few TDI threads there with mods they have done.
Slick and unclefester are a few to search for.
skullmunki
Ding Ding Round 2!!!
Nov 12, 2006
502
amen...i'm forever referring to festers thread! a good read!
Andrewcupra TDI
Resident Desk Jockey
Apr 30, 2008
3,282
in the mountains ( Wales )
Leon PD150* turbo inlet hose+airbox hose (1) Air AH33 £145.00
Leon Mk1 PD150 (3) With alloy fittings/joiners/clamps Turbo THS204/A £232.00
the intercooler inlet its THS213.1********************************************************************************* £69.00
You need to add 15% VAT and then take off you 25% discount.
glynn how much it set you back for the maf & thermostat then ??
Feb 1, 2007
1,602
Nottingham
The thermostat and the coolant were about £16
The maf was £59 exchange.
Had the cat removed from my car today cost £50, best £50 spent yet. Made a difference to the torque and power and the noise level.Well happy goes like it should do now! That oil from the turbo failure must of chocked it up a bit.
Glynn
