motor stopped working!!
jacko18
AVI! pull your socks up!
Jul 11, 2007
329
Oswestry
www.bebo.com
[:@] when i stop the car and turn it off the little motor that usually chirps up from on top of the rad isnt working?? i fiddle with the connection and it kiced back in again.so i took the connector off and gave it a clean with WD40, put it back on and it doesnt do anything now!!! is this a problem??? :wtf::wtf::wtf:
jacko
20vt CUPRA
Marcus
Apr 23, 2007
62
Cambridgeshire
If your on about the fan which comes on when you switch the engine off then this is the same problem i had. I fiddled with the fuse box on top of the battery and i was able to make it come back on again but after a while it would stop working. I eventually took the fuse box off and cleaned the contacts inside, where I found some plastic had melted between the contacts which was causing the fan to be intermitant. Since i have done this i have had no problems. Hope it helps.
jacko18
Jul 11, 2007
329
Oswestry
www.bebo.com
not sure if its the fan its like a little motor that sits on top of the rad on the left hand side.sounds like a pump of some sort.but il try that aswel mate, thanks for the response!
Oct 17, 2006
893
Walthamstow
the fuse's in the holder(top of battery) also linked to the secondary water pump - mine did the same - i took the fuse out, pushed in back in and worked for a short time but then stopped -
