My car is at JBS for a GT3071R fitting.
Songman
232
Ayrshire
caney said:
cheers mate! back on topic now though as eddy will shout at us[B)]
Apologies to Eddy - and a big thumbs up too! - can`t wait to see the results - should be fantastic
The standard pistons/crank are fine for 500 - just the rods are dodgy i`m told - I read that some of the Vortex guys have passed an incredible 700bhp now!!
Would think that the largeport head is advisable for big power
is anyone doing CNC porting of 1.8T heads in UK? -I know Cosworth are producing CNC jobs for Sub/EVO
EddyH
263
Pontefract
Unfortunately I think it's a bit late to go large port now as my head has already been sent off for matching to the valves, however the inlet valves will be 1mm larger diameter than standard.
Songman
232
Ayrshire
I`m sure the inlets on a ported smallport head will flow plenty enough - it would be interesting to see the flow data ported smallport/standard largeport
The theroists always worry more about flow capacity on the exhaust side - port/manifold/turbo/exhaust - any restriction there with big power outputs, and things get `difficult`:cry: - according to the flow data there`s not much difference between the exhaust ports in the two heads
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
caney said:
i've just bought this one and got it polished as well,much cheaper than the apr one!
Are you smallport or largeport Steve?
Dahlback does'nt port to largeport properly as the runners are very narrow still.
caney
600
hi bill,mine is still smallport got the mani off edd's sportec golf as he's having a custom one built by them:)
caney
600
ryan_s3 said:
Looks good for my up-coming largeport head with those graphs.
so come on then ryan what BIG plans have you got for yours then?or is it all hush hush;)
ryan_s3
1,270
No big plans steve,thought i told you at pod what i was doing.400bhp max, probably a bit less.
caney
600
EddyH said:
Update:
The pistons arrived last week, the block was sent off and has been bored out to suit the new pistons.
Rods arrived this morning.
up and running for gti?
EddyH
263
Pontefract
That's the plan but I think I may struggle to get it sufficiently run in to grace the strip but I'll do my best dependant on when it's finished.
Here's a photo of one of the 83mm JE pistons which I was sent today:
Geeba
Hmmm isnt this the same Edd that said "I like my ko3s and wont go big turbo?" Just gone HUGE everything!
Look forward to seeing it at the show...
EddyH
263
Pontefract
Yes. :rolleyes:
Truth is though I'd tried IHI and GT28RS and they weren't for me. However I tried a car with a similar setup to what I'm going for and it just felt right, I knew straight away it was what I wanted for my car.
ryan_s3
1,270
caney said:
you've already got a bit less! 360bhp:)
360bhp at 6100rpm then nosedive,
this time it will be 400bhp and held......hopefully.
I'll leave it too you guys for the big numbers!
caney
600
lovely lovely:p
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
5 valve pockets :think:
some higher lift cams?
wondering what CR from the crown of the piston.
shame you cant seem em when they're in the motor.
EddyH
263
Pontefract
The valve pockets also have me a little puzzled as the cams and crank are staying standard.
I agree it's such a shame that the pistons won't be seen.
EDIT: The cut outs are for use with high lift cams (which I won't have), the compression ratio is 8.5:1
