What mods are you running? Are you remapped?
Revo stage 1 and its getting louder!!
i think it sounds sweet!!!! Im getting a quite load chatter, completely different to my 007.
Apologies to refering back to the GFB hybrid valve again, but regarding the chatter... The GFB valve also did this when letting off at lower/mid-range revs. Letting off higher up the range on full boost (standard 7/8psi) gave a nice clean whoosh which GFB said is how it should be. It could just be a characteristic of the valve.
if it is chatter, that is something to worry about imo, not good for the life of your turbo, lasts months instead of years .......
But surely if the chatter was a sign of problems I would of had chatter on the forge 007p valve?
Ive checked all the connections & is fine, Followed all the instructions properly. The car drives fine as well. Another guy on here fitted the same valve & has 'chatter'.
Im not even sure if it is chatter but thats the only word I can use to describe it. Like an Echo/Chatter sound.
Its not like what you hear on some cars that chatter, it sounds like a louder version of the original 007p valve with some echo
As said it's probably a characteristic of the valve rather than actual turbo stall
anyone got any sound clips yet? im on the edge of my seat here, wanna hear what its like
If the turbo was stalling, surely your gonna get massive lag between gear changes? I dont get any more lag than when i had the 007 fitted. I still think its the noise from recirculating first and then the noise from the blow off with probably a bit of echo to add to that........only quick
Ive noticed no difference in performance since changing the valve. I doubt its anything to worry about. I will double check over everything tommorow when its light to be sure its on right.
Im 99% sure the valve just sounds like that rather than turbo stall because it still spools up the same...
no performance drop for me either.....I actually like the sound. Im gonna try and get a sound/video clip for everyone tommorrow.![]()
