J@mes said:well i think you can do the before and after logs for comparison,
No - I mean just ONE run. Would it be more scientific to do 4-5?
J@mes said:thanks for the logs mat!![]()
how did you do them? (so i know for next time!)
oh yea... i did all the logs in 3rd gear!!!
J@mes said:a slight hill yes, well more of an incline! only slight tho!
that was for the modded box! so this would have made a difference i gues!
as for meassuring blocks 2 and 3... would that have made a difference? which one should i be using?
cheers![]()
wild willy said:Try the same test with a clean standard paper air filter. From the tests i have done the paper filter outflows both the green replacement cartridge and the dynatwist. Not much in it but may push you into the 190's. When you get remapped you'll be well into the 200's i should think with those readings.
LCR mat said:should both read the same
ibizacupra said:
I have found the exact OPPOSITE on logs..
new paper filter vs Green p[anel vs dynatwist
paper filter flowed least (but not by much, but remembering they also clog up much faster being reliant on very small pore sizes for filtration)
J@mes said:ok no worries there then!
so its just back to the air temp!![]()
as for goin up a slight incline... will that affect the results at all?![]()
i mean i did the loggin on a very short part of a dual carriage way between 2 roundabouts, and i logged up and down both sides of the road for both the standard and modded box... so it should be a fair test in that respect!
as i said... il av to wait for some cold weather!![]()
J@mes said:i agree with bill... before i fitted my green filter element, i put my mouth close to it and blew some air at/through it and then i did the same to the OE paper element and you could definitely feel more air coming out the other side with your hand on the green one! thus proving the green filter is more efficient! great test i know, but still lol.
also the OE paper filter is about twice as thick as the green one, so obvioulsy that wont help... as for actual filtration, i gues the OE is better, tho i may be wrong! but im sure the green is good enough!![]()
cupra R con said:as a serious aside to this 'testing' is the green panel that much better, or even a bit better than a new paper filter? & the big question is does it rattle?
i only ask as i have access to a seemingly infinite supply of paper ones![]()
STEVEO@CYMRU said:dont know whether this has been mentioned but i took out my fogs and turned them into air feeds one for the intercooler and the other runs a 3 inch pipe straight into the air box i to am running a panel filter by green and the car feels much better than when i was running a cone , might try moving the battery so i can get a bigger pipe tho the 3 inch fits the air box nice and the intake where the lights were
steveo
i can't work it out either, but i DO remember seeing several posts on here to the contraryFeel said:My green panel doesn't rattle - I don't see how it could...
