Yeah its shaun. Been speaking to him this morning and i think both of us are coming along to ricci concept on sat morn to have a look. I rang the garage and they said RR is fully booked. So will probably see you there and pick your brains with car issues!
I know the list was full but quite a few people have dropped out now, also he might have time to fit you inn near the end of the day, thats what happened last year, Glad to hear you might make it there's not many seat owners round here
Dan think i'll get a RR and full diagnostics report to see if there is a boost issue.
philw has already told you what to do, plug it in and look at the ecu number, if you havnt got vagcom, find someone that has...... if its a cupra ecu then its been mapped and running sh1t, needs looking at, if its a cupra R ecu then it will be running fine, no point guessing tho, just plug it in and find out for sure
yeah it is! how long have u had yours for? dont know whether to keep mine for a bit or not? only bought it as a run around but now im quite liking it and wanting to spend on it..... but i also fancy a corrado vr6 lol
Mine has made very simialr power outputs to yours mate, but the torque is smooth the whole way through the map, and pulls from beginning to end. Its def about 40lbs down on torque compared to P-torque or Revo tho.
If you want a revo trial it wont work if the ecu has allready been remapped as i found out :(
Remove your scuttle panel and have a look at the code on the ECU that will tell you if its an R ecu or not mate
