Scotty_b
Leon Cupra 300R
Jun 3, 2004
6,014
66
Hertfordshire
Hello all, ive done a few runs and wondered what you all think.
Group A: '003 Group B: '004 Group C: '020
RPM Mass Flow Load Ign. Timing RPM Voltage Temperature Temperature Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization
TIME TIME TIME
MARKER STAMP /min g/s % °BTDC STAMP /min V °C °C STAMP CF CF CF CF
68.1 2480 64.5 100 18 67.19 2360 14.28 85 18 67.68 0 0 0 0
69.41 2880 94.19 100 6 68.6 2600 14.21 85 20 69 0 0 0 0
70.71 3320 117.28 100 9 69.91 3040 14.21 85 20 70.31 0 0 0 0
72.02 3760 134.69 100 11.3 71.11 3440 14.21 85 21 71.52 0 0 0 0
73.33 4200 166.08 100 10.5 72.42 3920 14.14 86 21 72.82 0 0 0 0
74.53 4560 175.64 100 8.3 73.73 4320 14.14 86 24 74.13 0 0 0 0
75.94 5000 191.58 100 9.8 75.04 4720 14.21 86 24 75.44 0 0 0 0
77.35 5360 203.5 100 9.8 76.45 5120 14.14 87 27 76.85 0 0 0 0
78.75 5680 203.31 100 11.3 77.86 5480 14.21 87 29 78.26 0 0 0 0
79.97 5920 202.97 100 11.3 79.15 5760 14.21 87 30 79.55 0 0 0 0
81.38 6200 210.25 99.6 13.5 80.48 6040 14.14 87 32 80.98 0 0 0 0
82.67 6400 212.94 99.6 12 81.87 6280 14.21 87 33 82.27 0 0 0 0
84 6000 12.03 16.9 34.5 83.09 6440 14.14 87 34 83.49 0 0 0 0
85.39 5400 202.14 100 9 84.5 5320 13.93 87 33 84.9 0 0 0 0
Code:
	TIME					TIME					TIME
If you use the code tags it's easier to read (# sign 2nd from right)
Cheers fella, is there a guide on hopw to do the tags etc? As i really have no idea what they are and how to use them!
http://www.seatcupra.net/forums/misc.php?do=bbcode
You air intake seems to go up about the same as mine on a run (13 degrees odd). Think i'd log 115 instead now you know thats ok and increase da boost keeping an eye on when it starts falling off, for drivability more than anything else. Increasing boost also increases timing (to a max of 3).
115 (to show requested & delivered boost)
118 (to show delivered boost & w/gate duty)
004 (maf values)
that'll be good for starters if you don't touch the timing.
Code:
Sunday	22	October	2006	13:47:31
1ML 906 032 A  		1.8l R4/5VT     G   0001
	Group A:	'004				Group B:	'115				Group C:	'118
		RPM	Voltage	Temperature	Temperature		RPM	Load	Absolute Pres.	Absolute Pres.		RPM	Temperature	Load	Absolute Pres.
	TIME					TIME					TIME
MARKER	STAMP	 /min	 V	°C	°C	STAMP	 /min	%	 mbar	 mbar	STAMP	 /min	°C	%	 mbar
	36.6	1960	14	84	24	37.11	2000	85	1770	1040	37.61	2080	24	100	1180
	38.01	2160	13.86	84	24	38.41	2240	112.8	1930	1420	38.9	2360	23	97.6	1590
	39.32	2480	13.93	84	23	39.7	2600	155.6	2160	1970	40.12	2760	23	76.9	2260
	40.52	2880	13.93	84	23	40.92	3040	174.4	2160	2190	41.34	3160	21	74.1	2190
	41.83	3320	13.93	85	21	42.23	3480	191.7	2250	2220	42.74	3680	22	74.9	2250
	43.24	3840	14	85	23	43.64	4000	191.7	2310	2270	44.04	4120	23	76.1	2250
	44.45	4240	13.93	85	24	44.85	4400	189.5	2320	2300	45.25	4520	24	76.1	2260
	45.65	4640	13.93	86	24	46.15	4800	191.7	2290	2220	46.57	4920	26	77.3	2220
	47.06	5080	14	86	26	47.56	5200	191.7	2270	2180	47.98	5320	27	88.2	2170
	48.47	5440	14	86	28	48.87	5520	191.7	2250	2190	49.38	5640	29	95.3	2140
	49.78	5760	13.93	87	30	50.18	5840	186.5	2240	2160	50.68	5960	30	95.3	2110
	51.08	6040	13.93	87	30	51.49	6080	183.5	2220	2110	51.89	6160	31	95.3	2070
	52.39	6240	13.86	87	32	52.9	6320	174.4	2230	2140	53.4	6400	33	0	2000
	53.8	5760	13.93	87	31	54.2	5160	142.9	2180	1640	54.6	5120	32	0	2180
	55.01	4600	14	87	30	55.49	4120	12	980	1100	55.91	4080	30	0	1050
	56.31	4040	13.93	87	30	56.72	4000	12	980	1030	57.22	3920	30	0	1020
	57.6	3880	14	87	30	58.02	3800	12	980	1020	58.53	3720	30	0	1020
	58.93	3680	13.93	87	30	59.43	3640	12	980	1010	59.83	3600	30	0	1010
	60.24	3560	14	87	30	60.74	3520	12.8	980	1010	61.14	3480	29	0	1010
	61.64	3440	14	87	29	62.04	3440	13.5	980	1010	62.44	3400	29	0	1010
	133.45	2360	13.93	84	22	133.86	2480	88.7	1570	1200	133.05	2320	23	0	1090
	134.76	2600	14	84	21	135.26	2000	25.6	1010	1060	134.26	2600	22	95.3	1400
	136.07	2120	13.86	84	21	136.57	2160	89.5	1890	1060	135.67	2120	21	0	1050
	137.48	2320	14	84	21	137.97	2400	128.6	2040	1610	136.97	2200	21	100	1200
	138.89	2680	13.93	85	21	139.29	2840	178.9	2150	2300	138.37	2520	21	95.3	1830
	140.09	3120	14	85	21	140.5	3240	182.7	2200	2160	139.69	2960	21	74.9	2160
	141.4	3560	13.93	85	21	141.91	3760	191.7	2290	2250	141	3440	21	75.3	2210
	142.81	4040	13.79	86	22	143.32	4240	191.7	2320	2270	142.31	3880	21	74.9	2290
	181.22	2120	13.86	81	26	181.63	2120	16.5	980	990	180.82	2120	26	0	990
	182.43	2240	13.93	81	25	182.83	2320	104.5	1980	1320	182.02	2160	26	100	1000
	183.74	2560	13.93	81	24	184.24	2760	170.7	2160	2160	183.25	2400	24	96.5	1490
	185.15	3120	13.93	81	22	185.55	3280	190.2	2230	2220	184.64	2920	23	70.6	2310
	186.46	3640	13.86	81	21	186.96	3840	191.7	2310	2280	185.95	3440	21	74.1	2250
	187.76	4160	13.93	81	23	188.17	4320	191.7	2320	2290	187.36	4000	22	77.3	2270
	189.07	4680	13.86	82	24	189.47	4800	191.7	2280	2210	188.67	4520	24	76.9	2260
	190.29	5080	13.86	82	25	190.78	5240	191.7	2260	2190	189.87	4920	24	78	2230
	191.58	5440	13.72	83	27	191.98	5560	191.7	2250	2180	191.18	5360	26	88.2	2210
	192.8	5760	13.93	83	28	193.2	5880	191.7	2220	2080	192.4	5680	27	95.3	2130
	194.09	6080	13.93	84	30	194.51	6200	178.2	2220	2060	193.69	6000	29	95.3	2090
	195.41	6000	13.93	84	29	195.92	5800	12	980	1100	195.01	6160	30	0	2220
	196.81	5080	13.93	84	29	197.21	4360	12	980	1040	196.41	5600	28	0	1050
	198.03	3480	13.86	85	28	198.43	3400	13.5	980	1010	197.61	3880	28	0	1030
	199.23	3360	13.93	85	27	199.63	3320	12.8	980	1010	198.83	3360	28	0	1010
	200.44	3200	13.93	85	27	200.94	3120	13.5	980	1010	200.03	3280	27	0	1010
If you were booting it in 4th, you could turn the boost up quite a bit. You sure that's LB9? From your first log, you could turn the timing up (V-Power?) but I would change boost first.
Have a search for the SPS Advanced User Guide.
Yeah i dropped her down a while ago when i fitted the FMIC and this is the first logs ive done, what do we think on the boost? HB5 and T8?
I know the CF's shouldnt really be ubove five but what about the rest?
