The LCR block is different from the 180, was hoping to see actual vs expected Lambda factors. No matter. Assuming the obvious here but you have tried driving the car with the MAF sensor disconnected, right?
Yeah mate made no difference at all, I disconnect it again just incase but when I first started having the problems I tried that. The DV doesn't make a noise like it did like the air ain't getting that far round if you know what I mean. Would a leaky intercooler cause this much havoc?
I got a Forge 007 on there, previous owner had a blow off valve on there so I put the correct one and corrected hose. Yeah I'm thinking a serious boost leak or turbo :cry:
I have checked what I can and can only presume it's leaking from intercooler (if that's possible) guess I have to see what happens at the smoke test. Cheers for your help mate I post what happens Thursday.
Checked DV like you said holds pressure until I let go of the top so all good. New development now as it starts to boost then dies now im getting a low sound like a deep sound of an exhaust then tries to boost??? This car is beginning to test my patience grrrt
Ok cheers mate, I've booked the car for a smoke test for Thursday. I checked all pipes I think the major ones all seemed ok. I found a split pipe under manifold which I replaced which didn't really have a major effect. It sounds like air is escaping or being sucked in where it shouldn't. Does feel like car is holding back so your probably right about the throttle butterfly is holding back hence the real massive lack in power. The rod seemed fine it was tough to pull but not sure about wastegate. Thanks so much for taking the time to check my logs I might pop and double check some more hoses but I got a funny feeling the sound is coming from intercooler on the drivers side. There's no oil around there which I would of expected if it was, be nice once it's storted I haven't been able to enjoy driving the car really. Thanks again to you and everyone for your input. I keep you all posted
to confirm throttle 003 block, boost actual 118
its not like you have Any boost tho, not even actuator pressure which would be 1300mb actual (ish)
[/URL][/IMG]
The numbers are the same all the way down to 16 on time stamp
bog std fuel lamfa
same blocks.
Different to mine Bill, last time I logged Block 031 it gave Lambda Factors rather than voltages:
Fueling:
Code:
Friday	30	April	2010	20:13:56
06A 906 032 HJ 		1.8L R4/5VT      01 0002
	Group A:	'031				Group B:	'115				Group C:	'002
		Lambda Factor	Lambda Factor	Bin. Bits	Bin. Bits		Engine Speed	Engine Load	Spec. Boost	Actual Boost		Idle speed	Engine load	Inj. period	Air mass in
	TIME					TIME	700-6800 RPM	15-150%	990-1800 mbar	<=1800 mbar	TIME	700-820 rpm	15-25%	2.0 - 4.0 ms	2.0-4.5 g/s
MARKER	STAMP					STAMP	 /min	%	 mbar	 mbar	STAMP	 /min	%	 ms	 g/s
	0.5	1.008	1	        	        	1.02	1280	32.3	980	990	0.01	760	19.5	2.38	2.75
	2.01	1.023	1	        	        	2.52	1280	33.1	980	990	1.51	1200	38.3	4.08	8.39
	3.52	0.977	1	        	        	4.03	1200	45.9	980	1000	3.02	1120	36.8	4.42	8.61
	5.18	0.992	1	        	        	5.73	2280	63.9	980	1120	4.62	1440	48.9	5.78	15.19
	6.75	1.016	1	        	        	7.24	1520	63.2	990	1040	6.24	1920	14.3	1.7	4.11
	8.25	1.039	1	        	        	8.76	2040	92.5	1350	1230	7.74	1640	72.9	7.82	24.61
	9.76	0.93	0.914	        	        	10.26	3040	154.9	2060	1960	9.25	2320	104.5	11.9	48.53
	11.33	0.828	0.836	        	        	11.96	4560	179.7	2100	2190	10.76	3480	162.4	20.06	105.83
	13	0.821	0.828	        	        	13.49	5840	151.1	1840	1840	12.48	5080	163.2	20.4	154.83
	14.49	0.75	0.774	        	        	15.01	6200	11.3	980	1420	14	6160	145.9	18.36	171.31
	16	0.805	0.914	        	        	16.5	4640	163.2	2030	2040	15.5	5200	12.8	0	11.25
	17.5	0.828	0.828	        	        	18.05	5160	157.1	1960	1950	17.01	4840	164.7	20.4	147.64
	19.22	0.75	0.789	        	        	19.73	5240	11.3	980	1370	18.71	5360	154.1	21.08	158.19
	20.72	1.991	1.047	        	        	21.24	4240	12	980	1030	20.23	4360	12	0	9.28
	22.23	1.991	1.047	        	        	22.73	4040	12	980	1020	21.75	4160	12	0	9.33
I won't second guess you because you know far more about this stuff than I do. I can understand using the Lambda Factors to confirm adequate fuel supply, but sensor voltages mean nothing to me.
you post lambda values here not voltages
incorrect label file on your vcds perhaps
Ok thought I let you know what's happened.
Was due for a smoke test but garage rang to say there machine wasn't working so ok fair enough.
I decided to check things over again, well in one thread I made I said the the BMA CDA filter had a gap round the maf sensor it had 2 nuts they used as spacers. Well I removed spacers and sat it flush. I did that the day I was looking for the boost leak I had which back then was a slight one. Anyway today I thought I would put spacers back just incase and well BINGO got all my power back!!! I must of fixed something else as there is no leak either! I reckon the filter must be caked in dust or something that it can only draw air thru that gap? Going to buy a replacement filter ASAP. Thank you so much guys for the patience and help to try and sort this for me. Now to sort the other problems out but least it feels like a Cupra R :1st:
