iirc you just block off the vac lines from the SAI reuvers can confirm this...your best bet is to remove the SAI and replace with resistors you will need a blanking plate aswell for the SAI otherwise you can get a fault code every so often from the SAI..
spot on
block them
Ok great, Hopepfully plan to do this soon. :happy:
Yeh I am going to remove the SAI, as well at fitting a catch tank. Its on my todo list :D
for the catch tank, please take off the inlet. its sooo much easier.
I installed one about a week ago, and took about 30 minutes, taking everything off and putting everything back on.
and yes silencer thats all correct! getting good at this are you...? ;)
