Malice19
.:Cupra 4 The Win:.
Mar 16, 2006
523
Swindon
Hi All
I’m sure I found a thread on this before but I done a quick search but could not find it?
I’m pretty sure that I need to replace the oil temp sensor as it seems to have a mind of its own, so I turn the engine on, run it for about 10-15min and the sensor will show 90, and then all of a sudden it will drop to cold then back to 90 and so on.
Most of the time once it has done that it will stay on cold, even though I have been driving for like an hour?
I have heard that it is most likely the sensor needing replacing... so can any one be kind enough to post the part code of the sensor as my local Swindon Seat is crap when it comes to ordering parts as they just bring up a picture of all the parts of the car and flick through till you see the part you need :blink:
Also I'm sure I have seen it some where a little guide showing you how to DIY to replacing the sensor? :happy:
Cheers People! :clap:
Oh yeah the car is a 2003 LC 1.8T :redface:
Hi All
I think you mean Coolant temperature sensor.
Aye your a star... Cheers mate for posting that ... will have to pop in to the local Seat and get it on order.... Thank God i don't have to wait there as he clicks the mouse button and asks me to say "When" i see the part i need ... What a Joke... :doh:
Thanks again :clap:
Can you give me the Coolant temperature sensor P/N again
mate
- (new model, green) coolant temperature sensor (part 059-919-501-A)
- O-ring seal for above (part N-903-168-02)
- Optional (may break when replacing) : plastic retaining clip (part 032-121-142)
Sorry to hijack the thread but it's on topic - I replaced my sensor with another green one after getting the same problem. But the gauge is still temperamental (drops every now and again, although not usually more than half way).
I'm also getting the EML light on intermittently with the common fault codes:
P0172 (system too rich)
P1137 and
P1297
Could the temp gauge problem be causing those?
And if replacing the sensor hasn't worked - what else could it be :confused:
Thanks in advance for any help
P1137 and
P1297
My guess would be your thermostate is faulty (doesn't fully close)
Quite sure actually ...
Had the same problem once
Spot on! Cheers for that mate, some thing to do on the weekend now.....[B)]
