Lee, lol, a bit confused here, looked at the pic and can only see the lock nut and bolt, where does the extra nut come into play?![]()
Drill the hole and put the bolt through add the nut to secure the bolt put on the linkage and then add the lock nut.
done mine, simple ten min job, and such a difference!! WOW, no going back to standard for me lol
http://www.youtube.com/watch?v=tp9ggefOjAEby the way you are best to reset all the cables and lock off the gearstick in the car as directed on the Forge website, otherwise you will find it very hard to get into reverse , and all the gears will feel 'notchy'
need any pics or owt giz a shout![]()
just done this after SEARCHING lol - Sorry Lee
You need M10 max length 50mm
1 x normal nut
1 x nyloc
Just be careful where you drill as the back end of the is not flat.
Whilst I locked both the box and gear lever and then adjusted, reverse is a little bit of a pain to reach.
Will try and tweak before the wiff gets in and throws her toys.
