I can't believe VAG are still peddling the 1.9 TDI - especially as a 90bhp model.. why would you buy that when the 1.4 TDI has 80bhp!?
Think it must be a typo as these are out of production...
Oh & the 1.4TDI had a 90hp variation amoungst others...
90-160 hp 1.9 TDI
The 1.9 TDI is the emblematic turbo diesel from Volkswagen, which developed the notion of various outputs of the same engine. In the Passat, the 90 hp (67 kW) was introduced in 1993, the 110 hp (82 kW) in 1996 and the first TDI with pump*jet direct injection in 1998 with 115 hp (86 kW). The EA086 is built in Puebla, Mexico for North America. These have progressively been discontinued, and now only the new 105 hp (78 kW) version is used on new models, like the Golf V, the Jetta and the new Passat. See TDI.
Configuration
1896 cc inline 4 cylinder
head
SOHC, aluminum, compression ratio 19.5:1
block
cast iron, bore 79.5 mm × stroke 95.5 mm
aspiration
turbocharger, cast aluminum intake manifold, bucket tappets
crankshaft
fracture-split forged steel connecting rods, one-piece cast camshaft
fuel system
DI fuel injection
output
VP37 (Verteilerpumpe)
66 kW (90 hp) @ 3750 rpm, 210 N·m (155 ft·lbf) @ 1900 rpm; VW Passat, VW Golf, VW Jetta and Jetta Wagon, VW New Beetle, Skoda Octavia – the older model still being manufactured in India, a pump injector version is still used in the Golf Plus and Touran
81 kW (110 hp), 235 N·m (173 lbf·ft) @ 1900 rpm with a variable nozzle turbocharger (discontinued)
PD (Pump injector) versions (Pumpe-Düse), compression ratio 19.0:1
55 kW (75 hp) @ 4000 rpm, 210 N·m @ 1900 rpm; VW Caddy mk3
66 kW (90 hp) @ 4000 rpm, 240 N·m @ 1900 rpm; VW Sharan
74 kW (100 hp) @ 4000 rpm, 240 N·m (177 lbf·ft) @ 1800-2400 rpm (Bosch EDC 17); Passat, Golf, Jetta, Jetta Wagon, and New Beetle, Škoda Fabia (still in production, used in Skoda Octavia Tour - the name of older model Octavia)
78 kW (105 hp) @ 4000 rpm, 250 N·m @ 1900 rpm; SEAT Altea, SEAT León, VW Golf V, VW New Passat, VW Transporter, Skoda Octavia II (branded 'Laura' in India because the older version of Octavia is still under manufacture) etc.
85 kW (115 hp) @ 4000 rpm, 285 N·m @ 1900 rpm (discontinued)
85 kW (115 hp) @ 4000 rpm, 310 N·m @ 1900 rpm; VW Sharan, Seat Alhambra, Ford Galaxy
96 kW (130 hp) @ 4000 rpm, 310 N·m @ 1900 rpm; VW Golf, Škoda Fabia, VW Polo Sport, VW Jetta, Passat, Audi A4, Audi A6, Gen. 2 SEAT Toledo,
SEAT Ibiza, SEAT Leon
96 kW (130 hp) @ 4000 rpm, 285 N·m @ 1900 rpm; Audi A4, Skoda Superb, Volkswagen Bora/Jetta, Golf, Passat & Polo Including GT (engine for the gear box with 5&6 speeds)
110 kW (150 hp) @ 4000 rpm, 320 N·m @ 1900 rpm; VW Golf IV, SEAT León Cupra and FR, VW Bora, etc. (discontinued)
118 kW (160 hp) @ 3750 rpm, 330 N·m @ 1900 rpm;
Seat Ibiza Cupra (engine exclusive to SEAT Sport)
70-90 hp 1.4 TDI
Configuration
Diesel 1422 cc (86 in³) inline three cylinder
Block
bore * stroke 79.5 * 95.5, grey cast iron
Head
2 valves, overhead camshaft, 18 to 19.5 compression ratio
Aspiration
variable turbine geometry turbocharger, intercooler, 2.3 bar absolute boost
Fuel
Pump direct injection, (PD Pump injector, Pumpe-Düse) Bosch EDC 15 engine management
Exhaust
Oxidizing catalytic converter, exhaust gas recirculation, EU4 limits
127 kg
Output
51 kW (70 hp) @ 4000 rpm, 155 N·m between 1600 and 2800 rpm
55 kW (75 hp) @ 4000 rpm, 195 N·m (144 ft·lbf) @ 2200 rpm (discontinued)
59 kW (80 hp) @ 4000 rpm, 195 N·m @ 2200 rpm
66 kW (90 hp) @ 4000 rpm, 230 N·m from 1900 to 2300 rpm (discontinued)
Applications
Audi A2, VW Lupo, VW Polo, SEAT Arosa,
SEAT Ibiza, SEAT Córdoba, Škoda Fabia , and most recently the Škoda Roomster
