Newbie, lusting over Cupra R
Mar 5, 2007
588
Well, none of that sounds desperately serious.
Never having heard a cupra R, does it sound any different to the older Cupra (someone at work used to have a 2001 Cupra), and does the newer DV (for the remap) make a diff to this?
Thanks for all the info guys. You know, I think I dreamt I bought a LCR yesterday!
IT MUST BE A SIGN.
RobM
Back from the dead...
Sep 27, 2006
4,982
Southampton
The exhaust on the LCR is different and the engine setup is slightly different, so the sound difference is evident for sure. I personally think the LCR is the most tuneful of the 1.8T engined VAG cars, as some of them tend to sound a bit flat.
The DV wont make much difference to the sound. It's a diverter valve and not an atmospheric venting valve so you don't get any real 'whoosh', but the aftermarket valves like the Forge 007P are a little louder (you can hear them dumping air back into the airbox). If you want a atmospheric sounding DV, check out the new Forge Split-R as this is a part-diverter, part-atmospheric valve that dumps enough air back into the system to keep the car happy, but still vents some air out to give the noise people want.
