Model Year 24/25 No Charging schedule
Jun 19, 2025
My Cupra Formentor is missing the ability to select charging times, use granny charger don’t do enough miles to buy wall charger. Have spoken to dealers and Cupra who have confirmed this update will be q3 which is July to September and should be OTA. Bit of a nuisance trying to get cheap electric off peak when I have no way of setting schedule, the older formentor models have this ability. Understand VW also have the same issues and are awaiting an update. Anyone found a way around this with granny charger until update arrives thanks.
Jun 26, 2025
I have a 2025 Formentor hybrid which was delivered about 7 weeks ago (loving it) and same as you just charging it from a 3 pin socket. I successfully set up a charging schedule in the car which then showed in the app so I could modify it. Now I plug it in at some point in the evening and it waits till 1am to start charging and stops at 6am. Not sure why you're having issues??
In terms of the 3 pin charging in replaced the existing socket with a bs1363/ev socket designed for charging ev's. Doesn't get hot at all and no harder to fit than a normal socket.
Jun 19, 2025
Hi cupra 985 on my screen for charging I am missing a line which included schedule. I only have batt manager charging e info and settings nothing for setting time or schedule. How do you do it or have you’re car got different software thanks
Jun 19, 2025
I now know why I’m still on the wrong software I’m on 2460 and awaiting the software update in Q3 July -September to allow charging
