Hey, just in the middle of fitting my w8 lights. just wondering which cable on the back of the headlight adjuster/ dimmer bit is the cable for not dimmed interior lights? err, havent had time to take a picture.
Best thing to do mate is put a multimeter in each of them and see which one's voltage changes with the dimmer. You dont wanna make a mistake on what someone else recommends as the light wiring may be different.
If your stuck by tonight though, ill take a pic of mine for you
lol, yeah 30mins is about right. parts cost me around £40iirc. the only thing is u gotta shut all your doors when u fit it. otherwise u might think uve wired it wrong as the lights are always on....yep i did that...took me a good 10 mins to resolve the issue.
you tap into the "dimmed wire" so u can hook up lights that will dim with the dimmer switch. the w8 light is just a better light with 4 bulbs, controlled seperatly. it also has two lil leds that shine onto your dash....
Here's a handy fitting guide for the sunroof version that I fitted, but you just miss out the sunroof control bit. Dead easy to fit - even for a novice like me: http://www.11tkp.co.uk/w8-light-install.htm
