Hopefully sorted!
So this morning I fitted my genuine cts that I bought from Sere motors NI. and it Went well. To be lazy, I bought a funnel and I cut a cuff of a 2l coke bottle and I unplugged the negative connection on the battery (ensuring I knew my radio code) and unscrewed the intake pipe from the air filter housing (the pipe that contains the MAF sensor), unplugging the maf sensor lead before doing so; so that I could move it completely out of the way. I then unplugged the cts connection, took out the u clip that is on the sensor. I dropped a 2l bottle into the engine bay and inserted the funnel. I then inserted the cuff of the 2l bottle I cut up before, to bridge a gap and act as a splash guard as I knew it would miss otherwise and I also wasn't sure if it was going to gush out or trickle. I left the reservoir lid on to form a vacuum but also had a bit of spare coolant ready in case. I then slowly prised the sensor off. It caught all the coolant it was going to dispel (between 1-2l) and I could then fit the new sensor and put my coolant back in. However.... The climatronic got to 90 but my temp gauge didn't budge off 60. I decided to go on a 22 mile drive of dual carriageway normal roads and motorway and upon driving the dash gauge quickly and steadily reached 90 (I'd obviously preheated so not surprised) both gauges read 90 on the whole journey without stutter so maybe the dash gauge just needed to calibrate itself - fingers crossed anyway and I will be monitoring it. The climatronic gauge; having switched off and on again is slowly rising up whereas the dash gauge went straight back up to 90 which leads me to believe that a) digital and analogue cannot be compared accurately and b) when reading the temperature it will always have to climb back up the numbers to show an accurate figure, which I think would explain the variances between the two gauges when I turned off the car before when idling it to temperature and then setting off on the 22 mile trip. For anyone reading this who is looking at other options than to spend money on parts.... Spend the money... Buy a genuine cts and if that doesn't work, a thermostat and don't muck about like I did trying to guess game it. The guys on here are right and I was wrong. It's a bit of trial and error - cheers
