In two minds about the tourque app. Just not entirely convinced that the readings are all accurate, but the main thing is that I have a hand scanner which has picked up 2 faults, but tourque doesnt. Connection is there, and I am getting all the realtime readings etc. Havent used it in a while, but for those that are using it now, has the dev added in any updates to allow the boost to appear for the LCR... I had a check on the forum a while back and there was an issue with blocks/custom PIDs etc.
Just for a laugh though, the realtime GPS logging of your journey (then overlaid with google maps) with limited telemetry is a pretty wicked feature, even if I dont use it that much - its just cool to look atI bought the full version, because its worth the few quid to keep the developer going.
yesgood times thanks lee does this do a tourque reading aswell?
that thing is huge (appears as at least to be)
any pic of space it takes up? as i use that space under ashtray a bit!
