Always good for businessNothing has to be factory fit to be coded apart from keyless start. Everything else can be retrofitted, even on SFD2 vehicles![]()
Beepoff sounds interest. It goes into the bus one assumes. Hence it has to be professionally fitted with all the handshakes and involvement of the mothershipWhat car? Non SFD2 - OBDeleven is fine. SFD2 -next to 0 DIY changes possible
www.beepoff.app launches soon, extremely useful for SFD2 cars
No, they do notin my OBDeleven app I can see some available one-click apps such as "Traffic Sign Speed Warning" and "Lane Assist Setting Memory". Has anyone tried these, do they actually work on sfd2 protected cars?
Pay for installation, pay if you ever change platform. That's itBeepoff sounds interest. It goes into the bus one assumes. Hence it has to be professionally fitted with all the handshakes and involvement of the mothership... pushing the boards graphics
Will be interesting to hear how people find it on each of the features by platform and cost. I note you are the developer.
I had a feeling they wouldn't. You'd have to look at the systems required, whether they were SFD2 protected and strike out the ones excluded. More than the A5 camera I reckon referenced aboveNo, they do not
sorry not sure I understand. Are you saying that one-click apps work on SFD2 protected cars? The ones I mentioned in post #583?The one click Funktion by SFD 2 Car works without Problem. The examble in Post #583
He was saying that but I wouldn't trust the answer without checking it. Obdeleven board will show which modules cant be accessed due to SFD2. The "code" which is really the procedure for coding it is shown on the thread. If a disallowed module appears in that code then it cant be done. The modules have two characters letters. You list of those in the mod against whether they are all allowed.sorry not sure I understand. Are you saying that one-click apps work on SFD2 protected cars? The ones I mentioned in post #583?
Aha ok that makes sense, I suspected the same. Thanks for the info!He was saying that but I wouldn't trust the answer without checking it. Obdeleven board will show which modules cant be accessed due to SFD2. The "code" which is really the procedure for coding it is shown on the thread. If a disallowed module appears in that code then it cant be done. The modules have two characters letters. You list of those in the mod against whether they are all allowed.
Post 585 from @East Yorkshire Retrofits says it cant be done and the check is as I said. Wearing my tutorial hat on now. The project is as the first paragraph. If I did it you wouldn't learn anything. I dont have a car with SFD2 so I'm not inclined to rummage about and do that check myself, I'd believe @East Yorkshire Retrofits answer. But that's the check.
I dont like those micro payment apps they can be unreliable. It's better to code and for that you need the pro license but to save buying it for your purpose you can study the published code on the thread and elsewhere and study the Obdeleven board which provides SFD2 information of which units are blocked off. In SFD (1) they were open then Vag closed them down for SFD2. I'm sure that German board I referenced where I linked the PDF from will also mention it.
The code is on post 1 of this thread.
The Obdeleven thread dealing with the subject is this:
SFD 2 unlocked for 2024 models | OBDeleven
Has anyone been successful in modding a 2024 year model? I learned from an expert coder that SFD 2 has not been unlocked yet. Therefore we are not able to code some of the things in OBDeleven in ourforum.obdeleven.com
You put the two together.
I wouldn't say that if I hadn't tested it. I've already changed the coding of the camera (control unit A5) on several vehicles with SFD 2.He was saying that but I wouldn't trust the answer without checking it. Obdeleven board will show which modules cant be accessed due to SFD2. The "code" which is really the procedure for coding it is shown on the thread. If a disallowed module appears in that code then it cant be done. The modules have two characters letters. You list of those in the mod against whether they are all allowed.
A5 is driver assistance. Not too sure where that got commuted to cameraI wouldn't say that if I hadn't tested it. I've already changed the coding of the camera (control unit A5) on several vehicles with SFD 2.
