When it quotes channels that is almost certainly a non UDS control module so does not apply to the MQB Platform cars (eg MK3 Leon)
https://forums.ross-tech.com/showthread.php?1905-UDS-Vs-non-UDS
So no way to access?
Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
Not using those instructions but there are lots of bits that have no description in Control Unit 19 so you never know.
With regards to Full Link I am pretty sure this is a SWAP enabled function so it needs dealer input.
But as always happy to be proved wrong.
I know you are correct but the meddler in me has to look....
Thats how we all learn mate, have a go and see what happens.
I am still playing with door mirrors only opening when I put in the ignition key but close when I lock the car.
Ill try it on mine and see if it worksI think that is on the Newer models, it works on mine but the mirrors open then close when I open the door.
Joys of VW Cars.
Yep that is how mine is set, it does work but ever time I open the car the mirrors unfold and then refold.
Do you have Kessy by any chance
I tried doing this yesterday, but got an error when attempting to apply the change. Any idea why this would happen?olding mirrors with a touch control
With this mod, mirrors will fold without having to be continually pressing the button on the remote.
1 - Module 09 - Electronic. Code (31347)
2 - Adaptation
3 - Select - Control Access 2
4 - Sub - Funk modus spiegelaklappung
5 - Change value By command via remote control look key
http://obdeleven.proboards.com/thread/17/coding-adaptations
I have a 2015 FR150 Tech Pack.@Harber96 what car do you have (year please as well).
When you say you got an error, what was the error
First thing I would do is clear the app data if you did not do that as part of the refresh.
Then I presume if you hold your lock button down the mirrors do close
No I don't have pro just yet. I used the 'try me' for 5CWhen odd stuff happens I always do app cache clear first just to rule it out.
Do you know have the pro version
