lanceneoman
The Turbo Power
Aug 24, 2008
144
west mids
ok firstly looking at my wheels and it seems that the last owner has rounded the wheel bolt off to like a size 13 and i cannot get it off.they have even drilled about a 6mm drill into it and i still cant get it off any ideas.
also, i need an oil change on my car and im not sure whats the best oil to get, its a 1.8t cupra. thanks guys
What type of socket are you using? If its the key that comes in the car kit, this may also be worn and it wont help matters.
If its a proper socket drive, make sure there is no wear. Then if this does not work then try the other type of socket. i.e if you have a hex drive go for the splined type drive.
If this still does not work, then weld a wheel bolt onto the knackered one. This worked for me once.
