if people are interested i may be able to get a batch fabb'd up
i forwarded them to phil cause it wont let me post
sent them to everyone, im sure someone will post.
It looks better now as I changed the connections to samco with better clamps but u get the idea
I was looking also at a double bottle, (Power steering & oil catch ) if people interested?
How hard was moving your battery Mike? Single fat cable to the rear?
yep, and had an alu bracket made, didnt even plan on moving it, impulse. Already ahd cable there for amp. dont have spare anyway. Thought that it would make room for water injection tank
Alu bracket for what? Did you just leave that stupid box from the top of battery in place? What sorta price for the catch tank?
I had an alu bracket made to hold battery in place in the tyre well. The plastic cover on top of battery still remains in engine bay as its a fuse holder, just trimmed down a bit
yes. and it stops oil getting inside the motor, gumming the throttle body and getting blown back down the intake over the MAF (ibiza) from the DV venting.
Bill, i have read some where that you run a seat sport baffled sump with a drain back for the catch tank.
What kind of fitting is on the sump for the drain back? push/treaded?
Also where is the is the drain back is it above the baffle or below?
Forgot to ask what size line for the drain back and breather system?
Cheers.
