my oil light flashes and it beeps 3 times , im prety sure its low oil presure . what causes low oil presure ?? do i need to get a new oil pump , or should i try servicing it first oil and filter ect . ??
this thread should clear things up, if not have another search about the issue, as well as google, as that throws up some VAG threads relating to a problem with the pressure sender.
As long as this light is in the square box in the centre of the dash and not in the circular gauge.
yeh first thing i did was check the oil and its fine . so do we not think its the oil pump then ? is it advisable to be driving it ?? cus it only does it now and then .
Chances are it is the oil pick up being starved of oil hence the oil pressure light showing.
The pick up and oil seal is less than £20 iic and the sump needs dropping to change it.
I'd be getting it done ASAP
just took mine out for a drive and gave it a foot full up the dual and after coming off,it has brung up the oil light flashing and beeping 3 times.oil level is fine as not long had it serviced.let it cool down and took it out for a drive again and no light until you put your foot down and it brings it up again.Do you think that will be what your describing is what is causing it? if so,is it a easy job to do? and what parts will i need to fix and change it all including sump gasket.
mine beeps 3 times on startup, the oil light constantly flashes, what ultimately does this sound like?, the manual says it should not be driven in this state but it runs sweet no flat spots or lumpiness
ok cool.will go see the stealers now then.Thanks.mine sounds fine too and drives with all the power.strange really.going to drive the missus car to go pick the bits up though lol
Wouldn't like to think, i just hope you have caught it in time.
If it's from the top, which it should be considering all the oil will drain down, the lifters will be running dry.
