Madhatter
141
12
Sat on arse
I was just wondering what typical temperature you are getting once the engine is warm. Mine is typically running at 100-104 which seems high. This is just with normal use, not caning it. I appreciate petrol turbo engines run hot but just wanted to check in case something is amiss.
On my tdi runs about 80-90 normal driving and around 100 on highway
But the water heats up slower than my previous golf mk4.
vag familia
My cupra r was running at 106 intill I serviced it yesterday and on idle it was 55 all the way home it was 55 to 65 thought maybe the old oil was getting hot but today it's at 100 agian so **** knows
Sent from my SM-G920F using Tapatalk
Normally around 90-95 in normal driving 100 motorway. Have had mine go upto 108 when I was on the motorway the other week in the hot weather. 1.4tsi
Fairly certain the manual says normal is 90 - 110
If there are any issues a warning light will come on.
Mine does 80 normal drive,around 100 on highway. Normal oil temp,no worry mate.
Just heat it up,and enjoy :)
vag familia
Most standard cars will run 90-95 once fully warmed up. Thats normal. Even after a good hammering, temps should not be much over 100.
100 - 108 in my 2015 Cupra. I assume if something was wrong the car would tell you somehow.
90 is too low
No. Its fine. Normal everyday A & B road. Weather makes it variable.
More revs, motorway etc. Higher temps.
Oil is a cleanser, coolant and friction reducer all in one.
On my 1.4 it's 90 most of the time, yesterday when it was hell hot - above 32 with heavy traffic it reached 100 - tbh I don't check it that often but rather glance trough when looking for something else...
