OIL Temperature
magic77
Soot Machine
Jan 20, 2004
898
Camberley - Surrey
any ideas if an oil temp sensor can be fitted to a TDI 110 engine. Since the turbo incident considering one to keep on top of temperatures in the car. Is there equivalent of point 10 on the TDI oil filer housing
LCR mat
LCR Eater
Apr 4, 2004
1,549
merthyr Tydfil
neil_f225 said:
w rating relates to viscosity when cold ( 0 being the thinnest) , whilst the other number relates to thickness when hot.
Obviously though although the W figure is lower it is actully thicker than when it gets warm
at cold it behaves like a '0' weight oil which is cold
at optimum temp it behaves like a 30 weight oil would at optimum temp
edc
Blue Leather & Shiny Bits
Feb 8, 2002
8,142
Surrey
www.clairecoileytrust.com
When this was raised months back I emailed my mate at Castrol and he told me that 150 deg C regularly on a road car will need very frequent oil changes even on a top spec oil.
neil_f225
521
might be interested in ur oil cooler matt. Does it include the necessary fittings/sandwich plate. Any pics?
LCR mat
LCR Eater
Apr 4, 2004
1,549
merthyr Tydfil
no its just the cooler itself I had sold the car by the time I recieved it
I can get a pic
it was sized to go behind the S badge
vern
I Miss Her Below!
Jun 17, 2003
2,020
N.Yorks.
seatcupra.net
Spot on ED 120-130 ish is o.k but 150+ and your pushing it, miles will take the tole and it will shear, i still say 5-6K oil changes on a modded lcr 5K makes sense as 1/2 way to sevice/oil change anyhow, and yes isay this even running SLX, now castrol edge BTW
neil_f225
521
but surely seat would have tested the engine/oil in excess of these temps if they are recommending 10k miles service interval. Some of the vw/audis are even longer with their variable limits.
vern
I Miss Her Below!
Jun 17, 2003
2,020
N.Yorks.
seatcupra.net
neil it is chipped/modded motors that reach these temps, standard anywhere arround 100 deg c mate :)
LCR mat
LCR Eater
Apr 4, 2004
1,549
merthyr Tydfil
CupraR-Rog said:
Although I changed the oil on mine every 10k before it was chipped, as it probably wasn't driven quite as VAG intended all the time...
yeah you were a granny. they intended ppl to give it some stick now and then.
edc
Feb 8, 2002
8,142
Surrey
Not my advice but does come direct from the horse's mouth of somebody who does the fomulations and testing in F1
neil_f225
521
mitchy are you using an autogauge oil temp gauge and sender. i have just changed mine for a racetech gauge as i find the autogauge ones hard to read in bright sunlight. Normal cruising with the cooler fitted now sits about 85C compared to 110C on the autogauge. Never goes past 100 compared to 120 with autogauge. Could it be the gauge is wrong? Anyone else using different gauges?
Mitchy
TTRS
Oct 12, 2004
2,310
Yes i am, perhaps i should change the gauge and the sender.
However have you fitted an uprated oil cooler? Is this the reason why your oil temp is reading lower than it used to?
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
is it the j3 autosport gauge? very hard to see in daylight.
mines an LC 242bhp
i get 95 with very gentle driving, 100 impatient drive and upto 120 when its just fun :D whats the usual temp drop when using a cooler?
also.... isnt 85 degrees a bit below normal operating temps?
neil_f225
521
no, oil temp with cooler fitted was 110c with autogauge but now 85C with racetech gauge. Was 120c without cooler. My friends new focus st never goes above 100C even when thrashing it. usually sits about 85C. I think 80-100C is normal operating temp for oil.
