simonsen82
100
birmingham
Hi all- basically few months after a custom remap from some bloke of ebay it turns out the maps are crap because my beeza is using too much diesel bloke from the garage which was doing my suspension ( he is doing all electric and he is really good) told me that he can change that but he needs a original map where i can get that? (my car is 2003 seat ibiza sport 130 bhp 1.9 tdi)
Anyone who knows what they're doing faffing about with maps should have access to the original map, its not like its an exotic map its a map that was used across a wide range of VAG cars so if he really knew what he was doing surely he would already have access to such a common map?
He is probably right that the map is **** if you bought it off someone on ebay though.
well this bloke from ebay he had loads of positive feedback so i thought he will be good. And my friend told me that he should change just boost set-up but he add some more diesel instead. I know that he should have this map but he hasn't got it
I wouldnt of gone with someone on ebay. why dont you visit a company with a clue. surely you have someone near you ?
There are good companies on ebay for considerably cheaper than elsewhere, sometimes even using the same map.
well this bloke had a company called www_remapscience_co_uk so i thought he is a profesional. So anybody knows where i can get a original map?
well he knows what he is doing basically he is saying that evry car has a different petrol map and that some check sums has to be same or something like that hehe. And thats why he needs original map. Can anybody help me with that? regards si
Have you contacted the original mapper to see if he has it saved?
Also, depending on how it was mapped (and assuming you have a diesel) the original map may still be on there and possibly switchable.
If you have vagcom, go into engine settings and softcode. Take note of your current code, change the leading 1 (or 2) which I expect is there to a 0 and save. Ignition off, then try it.
Worth a try
he says that they have mapped it as petrol car because they gave more diesel without touching turbo and tourqe settings and secondly he deleted old map thats why i need original one
if you want a standard map, ask seat to reset your ecu to factory settings
probably would charge you though
i would recommend cc tuning (not custom code) he would be able to give a decent map for your car
in burton on trent!
