Jaruba
39
Finland
Hello!
Seat Leon mk3 5F -14
CJSA engine (1.8 tsi) with DSG
Mileage: 89402km-55551mi
First problem, car keeps throwing this fault code. Local vag garage says it can be wire problem. When you clear fault code U can drive many days without warning light, suddenly it appears again.... Any ideas where to start? Coolant level is normal
1 Fault Found:
15462 - Control Circuit for Coolant Bypass Valve
P2681 00 [036] - Open Cricuit
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 19
Mileage: 89317 km
Date: 2017.05.19
Time: 11:24:34
Engine speed: 2252.75 /min
Normed load value: 11.0 %
Vehicle speed: 103 km/h
Coolant temperature: 99 °C
Intake air temperature: 12 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 13.281 V
Unlearning counter according OBD: 40
Engine: operating status: PL
Engine temp. management actuator: raw value: 1226
Engine temperature management actuator: stop open: 139
Engine temperature management actuator: after-run stop: 3959
RVC_SP: 72.25 °
RVC_AV: 72.72 °
RVCPWM: 0.000 %
Readiness: 0000 0000
Hello Jaruba. I have just joined this forum and have exactly the same problem with my car. So far, the engine coolant bypass valve and it's connector have been replaced but the engine warning light is still on. Did you manage to find a fix for your car ? Any help would be much appreciated !
P2681 00 [175] - Open Cricuit
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 24
Mileage: 168333 km
Date: 2023.01.27
Time: 19:58:15
Engine RPM: 931.00 /min
Normed load value: 12.9 %
Vehicle speed: 17 km/h
Coolant temperature: 96 °C
Intake air temperature: 9 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 14.960 V
Engine: operating status: IS
Engine temp. management actuator: raw value: 1271
Engine temperature management actuator: stop open: 144
RVC_SP: 75.25 °
RVC_AV: 74.92 °
RVCPWM: 0.000 %
I dont have leaking pump - level of coolant is still same, so why it looks like that connectors are shortened by liquid ?
Freeze Frame:
Fault Priority: 2
Fault Frequency: 24
Mileage: 168333 km
Date: 2023.01.27
Time: 19:58:15
RVC_SP: 75.25 °
RVC_AV: 74.92 °
RVCPWM: 0.000 %
did you fix this ?
did you fix this ?
