You should just get them under the arches although I am not sure if you can actually buy 15mm adapters, I thought 20mm was the minimum that these came in?
hiya mate yes i have the 15mm fk adapters for my deepdish merc alloys and yes they do stick out of the arch a little and also the cheapest place i found for the adapters was ebay from germany.
hmm what am i saying the damn lambo's have a 15mm spacer on rear and a 10 on front so shall go check the spacer on the back at the front and just hold the alloy on to check tommorow. Sorry bout all the hastle will update with results when im done lol.
ok update ordered the adapters and they have come in today problem being the outer bore part not sure if this is the right saying the curved outer part where the wheel sits on is 57mm but the alloy is 65mm would this cause any major issue?
yeah made sure the od and id were the required size so hopefully thats me sorted just need to make sure that they dont stick out to far before i order tyres
