Jan 13, 2010
440
UK
as above, shoud i block it off with a blanking plate or remove the whole egr set up and use a allards erg kit??
reason i want rid is that it makes my car sound like a jet at idle when egr opens as i have a straight through pipe with no silencers
If you dont want a light, reduce it with a 9mm gasket and reduce the EGR parameters with VAGCOM. It will still do its job properly, but less gas will be put back into the intake.
Jimski
as a fellow blt engine owner the noise is cool an most turbo cars whistle as idle
