Petrol engine sounds like a diesel
tonymorris
Hi
I am in the process of buying a Seat ibiza and went to see one today. It was a 1.2l, 2003 with 79,000 on the clock. What I found unusual is that it sounded like a diesel from inside the car. Not the knocking type of an old diesel more like a modern diesel. From the outside it sounds fine and revs without any unusual sounds, it only when inside the car it sounds like a diesel. Is this how Seats sound from the inside ??
kriso
_______ C U P R A _______
Jan 29, 2007
2,325
Brighton
The 1.2 is a 3 cylinder engine with a timing chain so does sound a little different to other petrol Ibizas. If the engine was cold, it will probably sound worse too.
tonymorris
HI
thanks for the reply. The clutch also makes a noise when changing gear. It sounds like there is something loose. It only happened when releasing clutch during a change of gear. When engaged there were no other noises. Also when does the timming belt have to be changed?
Nath.
The Gentlemans Express
Jan 1, 2006
8,619
16
EASTLEIGH, HAMPSHIRE
DON'T buy it then, buy one with a proper engine with 4 cylinders.
The 1.2 has a timing chain, the chain tensioners are a weak point and the chain can jump causing thousands of £ damage.
Get a 1.4 or a diesel, the diesels are very good so I'm told. the 1.8 turbo 20 valve is better though heehee.
stezo2k
Anjuna Monkey
Mar 15, 2008
2,804
Dudley
theres no way the car should sound like that, mines virtually silent when running. inside and out. mines around the same milage
i personally dont think theres anything wrong with the 1.2 apart from being underpowered. only thing i dont like about mine
________
Lovely Wendie
Mr_Dave
lnk cr b82rez 2g4!
Aug 8, 2007
1,302
Cheshire
1.9 PD130/160 engines or the 1.8 20VT engines are both awesome tbh ;)
1.9...stefan
HYBRID???
Aug 21, 2008
705
grimsby
classic 1.2 soundings... your lucky its not an ecotec 3cyc corsa.... they sound like tractors... should only sound diesel ish when tickover.... during revs should liven up a bit... as per clutch can u describe the sound a little better?
Alex 17
No Smoke No Poke
Aug 17, 2008
1,920
Bedale - North yorkshire
Stop hateing on the 1.2.. Its not them its just that 1... Mine sounded like nothing i coudent even hear it when i baught it..then i changed my exaust now its sounds beastly :)
tonymorris
Hi
As the clutch pedal is released after changing gear the was a short low level ring noise.It didn't happen all the time, but the noise wasn't there when changing down, only on changing up.
When I was driving it it was surprisingly nippy and responsive for a 1.2.
Jim H
214
Teesside
I had a 1.2 12v Fabia (same engine) as a Hire Car once, I loved the sound of it especially when you revved it, it sounded like a V6. It was very nippy around town and I got about 40mpg from it.
But compared to my vRS out of town it was very underpowered, when you put your foot down it just made a noise and didn't do much, although TBH I preferred that sound compared to mine.
tkjeeves
Blue
Jul 13, 2008
333
oxford
i had a 1.2 3 pot polo 9n for a while, and it too sounded like a diesel when you first start it, in fact my 1.4 sounds like a diesel on the initial ignition. from what i remember the 3 pot does sound different, buzzier sorta sound, not sure if that's because of the chain cam, bit like the 1.2 Corsas too. The polo was a nice car though bit underpower because of the polo's body.
As with the clutch, i'm not liking from what you describe, avoid if you havent bought it yet.
