In preparation for this weekend's removal if the SAI
When i start my car from cold and the secondary air pump kicks in (during choke) it sounds like a Dyson hoover, i've tried re-sealing the pump but it didnt work and im not buying a new one at a £300 cost.
No benefit of removing it except the noise goes away when i start it from cold. I believe the pump is simply there to heat the cat up quicker during choke to reduce emissions or something.
Yeah it's been blowing since i got it but i knew it was a common fault, the older ones, mk3's etc are held together with rivets which you can replce with bolts to stop the noise but the mk4 ones are sealed :(
I take it you dont have this noise yourself then?
Lucky you :(
I'd happily replace it if it wasn't so dam expensive, less than £20 to remove it or £300 for a new one is a no brainer lol
I spend a bit of time on a camp site in Ayr, cant really be having the car sounding like a hoover in the early hours and pissing everyone off lol
One of 2 wee things annoying me about it. Nothing to do with how it drives though, it's spot on no problems there, just a couple rattles and things.
There's a rattle from the speedo surround, the clear plastic rattling against the black plastic, easily fixed. When the windows are partially down they rattle as well, the wee locator clip in the door frame needs bending back to stop this.
Just stupid little things really lol
Aye common problems it appears, there is a knocks and rattles threads for the mk4's. Says in that there's a wee latch like thing behind the door card to keep the window firmly in place, over time it bends so needs bending back to fix the rattle lol
I've got a dreadful rattle from my interior light under acceleration! It's god dam annoying!
On the Sai front, mine does this and it's a diesel I think it sounds good, but I think it's just the turbo as I hear it through my new exhaust :)
Sam
